I m too not sure about my pass b1 - Page 3 - diyAudio
Old 27th January 2013, 10:26 PM   #21
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by zygibajt View Post
To me it sounds fine, maybe even nice but somehow flat and uninvolving.
when that happens I usually blame the speakers
Old 27th January 2013, 10:43 PM   #22
I built B1 some 1,5 years ago and also wasn't satisfied with it sonically.
I used the best parts with Caddock resistors Siemens MKV coupling caps, cardas wire, Cardas solder, Matched J fets etc.. I powered it off batteries and used stepped attenuator as volume control.
To me it sounds fine, maybe even nice but somehow flat and uninvolving. The music does not flow, no emotion, no extreme 3D and separation.
Classic Aleph P 1.0 I have sounds much better to me.
I tried to come back to B1 many times but it's always the same. I still have it somewhere laying around.
Just build another /diffrent project, maybe it's not for you.
k thanks for that, what would be a better project for sure?
Old 27th January 2013, 10:54 PM   #23
But not if that doesn't happen with another preamp in the same system.
Old 27th January 2013, 10:58 PM   #24
I have no idea, it probably all depends, i belive some are extremely happy with B1 and it depends on the system and preferences probably, it is just you are not alone what i wanted to say. I'm not impressed with B1 that's it, does not work for me. I belive some Pass production preamps to be better than B1, maybe not in every system but most. I have no idea what to recommend, maybe others can help what other preamp might be worth of building if B1 does not work for some.
Old 27th January 2013, 11:54 PM   #25
The one and only
Nelson Pass's Avatar
Assuming that it is working correctly, the B1 is very neutral. It's not even
really a preamp - it's a buffered volume control. There are plenty of people
who aren't looking for that, and it's no problem by me if they prefer something
else.
Old 28th January 2013, 08:39 AM   #26
no I didnt,..............................
should I still take them out and measure them?
I told you many posts ago to measure the Vgs. See post4.
Have you done that yet?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th January 2013, 08:45 AM   #27
on the contrary
..... what would be a better project for sure?
to bring life to dull sound... 6V6 tube line pre (by Salas)
Old 28th January 2013, 09:33 AM   #28
kroyin is offline kroyin  India
You use a pot with the B1 ? If yes is it mono/stereo and what is the rated impedence of the pot(s).
I had a lifeless B1 (again very subjective opinion totally based on one's chain) with optical volume control (impedance of ~13k). Swapped the optivol with 2 mono Log Pots of 25K impedance each and things became a LOT better
Old 28th January 2013, 10:41 AM   #29
Originally Posted by kroyin View Post
...... with 2 mono Log Pots of 25K impedance each and things became a LOT better
which I guess makes it more a matter of your source output
Old 28th January 2013, 10:47 AM   #30
Well i'm not so sure, with DCB1 and the same source and the same optivol, the performance is extremely good.
But then what do i know
Mesmerize B1 vs Original Pass B1 - please guide me! KT Pass Labs 9 6th September 2012 05:57 PM
Pass B1 Buffer mantha3 Pass Labs 2 26th January 2012 11:35 PM
Pass B1 DIY - Need Help jung4g Pass Labs 28 25th January 2012 03:00 PM
Need help with Pass B1 Buffer benproiii Analog Line Level 0 30th August 2011 04:18 PM
Wanted: Pass B1 macnugget Swap Meet 2 21st April 2011 02:11 PM
Copyright 1999-2017 diyAudio
