Another ZenV4 up and running - diyAudio
Old 17th November 2003, 07:45 PM   #1
Thumbs up Another ZenV4 up and running
My ZenV4 has been up and running for a couple of weeks now. It sounds great. I sent a bunch of pictures to PassDIY with description and hope it shows up there soon. I have included a photo or two below.
Many thanks to Nelson Pass for his contributions to the DIY community. There are lots of kits and such out there, but NOTHING ELSE in the rarefied atmosphere of Pass designs. This has, of course, been true since the A-40 way back when. It is still true, close to 30 years later.
Larry Wright
Seattle area
Old 17th November 2003, 07:47 PM   #2
And another
Old 17th November 2003, 07:48 PM   #3
One more.
Old 17th November 2003, 08:30 PM   #4
Jaac is offline Jaac  Netherlands
Jaac's Avatar
lthe look is good but how does it sound ???
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Old 17th November 2003, 10:24 PM   #5
As I said, the sound is great. Handles low level detail especially well, and resolves delicate nuances lost with lesser equipment. Take a really well recorded disc (like, say, a Chesky Recordings disc) and listen for soundstage, ambiance, finger noises on strings, etc. Voice is especially natural sounding. There is a short recording of Sara K. singing on a Chesky sampler that makes you sit up and take notice on my Magneplanar Mg-12's with this amp (and they are power hogs that are recommended to be used with 40 to 150 watt amps). The Stereophile test CD tracks are revealing too of this amps ability to resolve hall ambiance, soundstage, and depth. When the guy on the test track takes the clicker noisemaker and says "I am now 30 feet behind the mikes" it SOUNDS like he is 30 feet behind the mikes.
Best of all, the music sounds natural and does not wear you out after 20 minutes. When you can get all this and heat your basement listening room too, hey, what's not to like.
Larry Wright
Seattle area
p.s.- makes Goldfrapp sound good too, and Frank Sinatra on Reprise recordings as well.
Old 17th November 2003, 10:30 PM   #6
Bricolo is offline Bricolo  France
Bricolo's Avatar
I'm sure Nelson will be glad to know that
Old 18th November 2003, 10:04 AM   #7
SuppersReady's Avatar
Default Nice work!
Well executed Larry,
I particularly like the way you have produced the two channels identically so that they fit comfortably 'back-to-back.'
Paul
Old 18th November 2003, 11:36 AM   #8
[QUOTE]Originally posted by Zapped
[B]As I said, the sound is great. Handles low level detail especially well, and resolves delicate nuances lost with lesser equipment. Take a really well recorded disc (like, say, a Chesky Recordings disc) and listen for soundstage, ambiance, finger noises on strings, etc. Voice is especially natural sounding. There is a short recording of Sara K. singing on a Chesky sampler that makes you sit up and take notice on my Magneplanar Mg-12's with this amp (and they are power hogs that are recommended to be used with 40 to 150 watt amps). The Stereophile test CD tracks are revealing too of this amps ability to resolve hall ambiance, soundstage, and depth. When the guy on the test track takes the clicker noisemaker and says "I am now 30 feet behind the mikes" it SOUNDS like he is 30 feet behind the mikes.
Larry,
More can be gotten out of this fine design. The low end seems to not mate well with some speakers. Some alter the feedback loop.
On mine I cranked the current up going through the input buffer from 8 ma to 23 ma. Made a large improvement in dynamics and in the low end punch.
This is my first solid state amp since 1989. I love it!
George
Old 18th November 2003, 06:45 PM   #9
Thanks to Panelhead for suggested mods, and to SuppersReady for kind comments.
The layout was pretty much determined by the size of the heatsinks (which I bought as parts in 1980 and kept in my garage ever since, waiting for the appropriate use! They are old Heathkit 250wpc super amp units) and my desire to have a front panel with width to height ratio of 1 to .618.
Sinks, by the way, turned out to be just about right, thermally. I did a rough calculation using an estimating program (ESB's? I think) and it looked to be approx. .3degrees per. In actual use, the attached photo shows my temperature probe taking a measurement at the hottest point, near the center bottom of the sink base plate. After about two hours this hits 53 to 54 Celcius at that point. The fins, top, and ends of the sinks are a lot cooler than this point. I may take the old functionally useless T0-3 covers off sometime and put a flat copper bar in their place to help spread heat more. Right now, I am too busy listening to the amp!
Old 18th November 2003, 08:07 PM   #10
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
more pics!
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 03:34 PM
Balanced ZenV4 again stani772577 Pass Labs 9 5th August 2004 12:03 AM
My ZenV4 Monos Orgonom Pass Labs 21 5th March 2003 06:02 PM
ZenV4 PSU noise PsykoK Pass Labs 36 12th December 2002 01:25 PM
capacitors for my ZenV4 PSU PsykoK Pass Labs 0 3rd December 2002 02:07 PM
Copyright 1999-2017 diyAudio
