Aleph 2 uneven temperatures - Page 4 - diyAudio
Old 5th February 2013, 09:13 PM   #31
AAAudio is offline AAAudio  United States
I haven't measured with new configuration of rc. The amp is completely silent with my ear placed directly on high efficiency speakers. The caps are 50v 69,000uf
The amp is quite manageable. It will be encased in black plexy once finished
Inviato dal mio GT-I9001 con Tapatalk 2
Old 5th February 2013, 09:38 PM   #32
MEGA_amp's Avatar
Out of curiosity, are you measuring amp draw with a current meter on the AC line? If you are, it should come out to 2.5A as stated in the service manual.
Old 5th February 2013, 09:52 PM   #33
Originally Posted by MEGA-amp View Post
Remove R19 (ref Aleph2 schem) and leave open. Sweet amps!!
Why remove R19? What is the value and where is it in the circuit? What does it do?
Old 5th February 2013, 10:01 PM   #34
MEGA_amp's Avatar
R19 trims DC bias, it's found in the upper portion of the output stage current source. 56.2K is the value for Aleph2.
More discussion:
DC offset / Bias setting for Aleph 2
Old 5th February 2013, 10:08 PM   #35
More discussion:
Thanks.
A friend of mine built me a pair of Aleph 2's about 6 years ago using KK boards. I had planned to have a look at their internals anyway and see what could be upgraded. This goes into the box of "must check ..."!
Old 5th February 2013, 10:11 PM   #36
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
bias schmias
(ref Aleph 2 schm , as Mega-amp said)
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 6th February 2013, 09:15 PM   #37
I measured 1.2v drop across 1ohm resistor. My transformer is boosted to 250v primary. I am using 300w of power. Strange for an aleph 2 with no 56.2k resistor!
Old 6th February 2013, 09:22 PM   #38
MEGA_amp's Avatar
The 1 ohm you have in the PS? That's not how you measure the amplifier bias.
This one needs clarifcation.
Old 6th February 2013, 09:26 PM   #39
I usually measure bias using the 1ohm 1% resistors in the rc network. 3.5A on the positive rail and 3.2 on the negative rail.
My transfor is deisgned for 230v but i increased mains to 250 via a step up transformer to increase voltage output. Simple.
Old 7th February 2013, 12:25 AM   #40
MEGA_amp's Avatar
Ok, got it on the transformer front.
Bias for Aleph 2:
Looking at the lower portion of the output stage (the 6 drive outputs):
(voltage across Source resistor / Source resistor value = current in that device)
0.5V/1R=0.5A or 500mA multiply that by 6, which is 3A.(0.5*6)
I'm not quite sure what the voltage across the lower source resistors will be when R19 is removed, but it will no doubt be higher, my guess is prob 10mV or slightly higher. For ex. when I removed R19 in my Aleph5, it jumped from the standard 0.5V to around .64-.66
You don't measure amplifer bias by voltage across a PS resistor. And the positive half of a Class A amp bipolar power supply will generally have a slightly higher draw than the negative half.
Looks to me like you're right on target. Hope that helps! To the experts, correct me if I'm wrong. I just read stuff and regurgitate it.
-John
Do you measure component temperatures? Greg Erskine Solid State 26 26th January 2011 10:00 AM
Playing stereo in cold temperatures ? Robcrx Car Audio 3 15th March 2010 06:18 PM
tube temperatures woodturner-fran Tubes / Valves 3 13th April 2006 07:27 PM
Survey - Actual Amp Temperatures keypunch Solid State 8 20th December 2004 01:57 AM
Question about Soldering Temperatures KT Chip Amps 6 9th June 2004 12:07 AM
Copyright 1999-2017 diyAudio
