Aleph 2 uneven temperatures - Page 3 - diyAudio
Old 23rd January 2013, 10:59 AM   #21
AAAudio is offline AAAudio  United States
Thank you. Now a mosfet is cold!
I am thinking the batch was flawed. I ordered 1% 5w 1ohm resistors for the mosfet source. I hope this improves the matching!
The funny thing is that bias drops with time. it is supposed to be 3A and that value is reached only in the beginning when the amp is cold. then it drops to 2.56A. could it be a "cold" mosfet is causing this?
Old 23rd January 2013, 11:09 AM   #22
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
no pictures , no measurements in important points , and you are expecting even additional confirmation of everything we replied to you ?
I understand lack of experience , but you really need to read what people are replying
temperature equilibrium is just that - equilibrium - it doesn't matter is it on 35 or 50C
crank up that bias and enjoy
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th February 2013, 08:55 PM   #23
Inviato dal mio GT-I9001 con Tapatalk 2
Old 5th February 2013, 08:56 PM   #24
Old 5th February 2013, 08:58 PM   #25
I am waiting for some components for second channel. Strange thing is that positive rail sees less current than negative rail. 3.5A vs 3.1A
I am waiting for matched irf9610 to reduce dc offset
Old 5th February 2013, 09:00 PM   #26
Ah i forgot the heatsinks do still get quite warm but i plan large undervolted fans under it (20cm x2). the heatsinks weigh 15kg each 60x60x10cm
Old 5th February 2013, 09:01 PM   #27
MEGA_amp's Avatar
Remove R19 (ref Aleph2 schem) and leave open. Sweet amps!! Are those wheels I see? I've used some 12V Noctua fans, seen in CPU heatsinks, undervolted by a few volts, they are silent.
Old 5th February 2013, 09:03 PM   #28
Thanks. Yes i removed r19 completely. I plan.on installing two ixys brick mosfets and.make thwm interchangeable. Yes there are wheels so i can move it around (80kg + )
Old 5th February 2013, 09:04 PM   #29
Second channel is still missing but i am also planning to add 250000uf of caps per channel to allow for higher bias
Old 5th February 2013, 09:07 PM   #30
MEGA_amp's Avatar
more bias doesn't necessarily require more PS caps, however it will help lower PS ripple. Is that 6X60000uF per channel? If it is, I think you have enough.
Do you measure component temperatures? Greg Erskine Solid State 26 26th January 2011 10:00 AM
Playing stereo in cold temperatures ? Robcrx Car Audio 3 15th March 2010 06:18 PM
tube temperatures woodturner-fran Tubes / Valves 3 13th April 2006 07:27 PM
Survey - Actual Amp Temperatures keypunch Solid State 8 20th December 2004 01:57 AM
Question about Soldering Temperatures KT Chip Amps 6 9th June 2004 12:07 AM
Copyright 1999-2017 diyAudio
