#81 |
Lightning In A Bottle
#82 | |
Best regards. |
#83 |
If you drive your search engine back a few more years, you'll find several posts of Papa about his parallel bank experiment with 100 small signal bjt's, mentioning on one occasion that he'll do it with JFETs one day.
That was before the SIT, so it was already in the works. (then again, I don't even know what goes on in my own mind)
Not so much,.......if it says "ZM" in the corner. |
#84 |
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#85 | |
Best regards |
#86 |
The one and only
Sounds like a good project for you.
#87 |
Mr. Pass. Thank you for your proposal. Unfortunately, my line of work is Chemistry. It will bury me. I wonder how often our diyAudio site is visited by Solid State Physicists, and Electronics Engineers from chip makers [worldwide] hunting for ideas and connections to make new devices. Since there is a great supply of the individual FETs, their makers are not inclined to change this profitable course. Your hand-made Beast is an engineering feat. A thousand DIYers practicing it will amount to a demand surge of 2 million pieces. TOSHIBA's execs are happy.
Allow me to return the favor of your proposal with the following ideas.
Best regards. |
#88 |
What interested me was the sonic signature was not as predicted.
I am trying to think if this insight would indicate a direction for more practical development. Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
#89 |
The one and only
Speculatively, perhaps 2nd harmonic is not the only source of "sweetness".
#90 |
Fortunately, this Mimick maybe as simple as a power buffer from a modified F5 and/or its descendants. A representative schematic is attached [jpg and identical pdf]. Note the following.
| Beast with a Thousand JFETs | Nelson Pass | Pass Labs | 297 | Today 11:38 AM |
| Guidelines for switching N-channel JFETs to P-channel JFETs (and vica versa)? | Test Electrix | Construction Tips | 9 | 24th January 2011 06:22 PM |
| Thought experiment: A thousand 12V car batteries in series | bigwill | Everything Else | 6 | 21st June 2007 03:56 AM |
| The Beast... | sklimek | Tubes / Valves | 5 | 29th June 2005 04:04 PM |
| Hello from the land of thousand smiles, Thailand | fahlap | Introductions | 2 | 26th December 2004 05:32 AM |
