Article: Beast With a Thousand Jfets
Old 23rd January 2013, 01:44 AM   #71
Loudthud is offline Loudthud  United States
Loudthud's Avatar
The parallel combination of 100 opamps with 560 ohms in series with the output would give an output impedance of 5.6 ohms. The opamps have short circuit protection, they don't need that big of a resistor. The input offset is low enough that something like 10 ohms would work fine.
Old 23rd January 2013, 02:18 AM   #72
Loudthud's Avatar
At an output of 20mA each opamp the output voltage can swing to about 2V from the rail. With 18V rails you have 16V peak, 2 A peak (20mA per) , that's 16W rms with 8 ohm load. Distortion raises quite a bit if you want too much gain or too much output current, especially at higher frequencies. Keep the output buffers at a gain of 1 or slightly higher. There is probably a better part out there.
I didn't try to figure out which package is best, probably the dual in 8 pin DIP.
Data sheet: http://www.ti.com/lit/ds/symlink/opa134.pdf
Old 23rd January 2013, 07:38 AM   #73
R-K Rønningstad is offline R-K Rønningstad  Norway
R-K Rønningstad's Avatar
Originally Posted by Zen Mod View Post
isn't place for damn 8-legged bugs in some other thread ?
Then we are at least two who believes so!
Old 23rd January 2013, 07:48 AM   #74
portreathbeach is offline portreathbeach  United Kingdom
OK. I have now posted my question and schematic here:
http://www.diyaudio.com/forums/chip-...ml#post3338443
Old 23rd January 2013, 06:27 PM   #75
Dzius is offline Dzius  Poland
Dzius's Avatar
It takes debuger !!!
Old 23rd January 2013, 08:19 PM   #76
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Maybe you want to see what Douglas Self has done with this.
Old 23rd January 2013, 08:27 PM   #77
Cheers Nelson. I've just downloaded the PDF of the design, very interesting read. Will have to make a similar thing
Old 30th January 2013, 11:13 PM   #78
Antoinel is offline Antoinel  United States
Default Maybe Large Scale Integrate [LSI] this Beast
This Beast may lend itself to LSI on a Si and/or a SiC wafer. Afterall, each individual P and N channel FETs belonged to a field of hundreds or thousands simultaneously made on a wafer by TOSHIBA or other. There is a precedence with CMOS Hex Inverters. Ditto for OP Amps which are also made by the tens or hundreds on a single wafer. Just link'em up.
The meticulously hand-wired prototype Beast worked with impeccable performance. The ongoing interest by DIYers worldwide may drive demand for the handmade and LSI Beast versions. The LSI Beast may have a lower cost than hand made.
Best regards.
Old 31st January 2013, 12:20 AM   #79
Blues is offline Blues  United States
Blues's Avatar
Like I speculated before, I think Mr. Pass put together these little monsters to characterize it as a whole and reference it for his Pass SITs production...
Old 31st January 2013, 12:42 AM   #80
Blues: Please direct me to the post of your speculation.
Article: Beast With a Thousand JfetsHide this!Advertise here!
Beast with a Thousand JFETs Nelson Pass Pass Labs 297 18th May 2013 12:38 PM
Guidelines for switching N-channel JFETs to P-channel JFETs (and vica versa)? Test Electrix Construction Tips 9 24th January 2011 07:22 PM
Thought experiment: A thousand 12V car batteries in series bigwill Everything Else 6 21st June 2007 04:56 AM
The Beast... sklimek Tubes / Valves 5 29th June 2005 05:04 PM
Hello from the land of thousand smiles, Thailand fahlap Introductions 2 26th December 2004 06:32 AM
