#81 |
I have big request : know anybody here, which firm made cinches for Mark Levinson ( horisontal mounting on PCB, all metal, without nut ) - or some similar high quality ? I can't WBT type or cheap ones which we can see on Freds picture. Thanks.
#82 |
WBT makes PCB mount RCAs.
http://www.wbtusa.com/wbt0234.html
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#83 | |
It'll be interesting to find out what happens when he builds it. Since we're summing two signals that drop at 12 db/octave, I'll bet it means he'll get 24. LR with a single gain stage? OK, Uli, wake up and get building Perhaps the master can enlighten us without giving away too much of his crossover article. |
#84 |
diyAudio Retiree
"I hope you using are using decent current sources....."
With cheap RCAs? That would be tacky and in bad taste, like wearing white shoes after Labor Day. Chris Sommevigo gave me those RCAs and I don't think they were that cheap ........ He had better send Cardas next time! Are they current sources or sinks, and just what is the difference exactly? Fred Send Cardas when only the very best will do. |
#85 |
diyAudio Retiree
"It certainly is true that the brighter of our readership can reverse engineer an XVR1 from the owner's manual."
Brighter than me..... I cant seem to figure out the resistor/ frequency steps from the 18K and 4.5 K resistor packs. Knowing just the one of the capacitor values might nudge me toward it but that would be cheating and take all the fun out of it. I seem to remember some thing about changing resititivity mid track to fake a non linear relationship. There is also the law faking resistor with a linear pot....... Could this be the case of a single word ( or capactance value being worth a thousand pictures and what is that that faint bwaa....haha noise in the distance? Of course one could save himself the agrevation of pondering and a sporty PCB layout ( Autorouter anyone?) for connecting a series resistor matrix and use an array of resistors than can be selected in parallel combinations. During the excellent Earth to the Moon series in the episode about building the LEM, one of the engineers worried about the translation of axis during docking when looking out the top window. Tom Kelly told him "The astronauts are smart guys, they will figure it out. Hmm... Several jumpers in a short parallel resistor programming header or one in a long series header (times one, two, or three or four programing headers corresponding to the filter order )? I wonder if that woud work with the capacitors as well....... Design of crossover filters requires great peace of mind. |
#86 | |
diyAudio Editor
#87 |
To Peter Daniel : I was saying, that I CAN'T WBT - I need name of manufacturer, which makes it for ML - or they are custom made ?
#88 |
I love Uli's innovative design but looking through all the literature it makes me wonder if Mr Pass has already done these hard yards before us.
"It was created over a period of several years for our own loudspeaker design efforts, and it is the design that ultimately performed with the most flexibility and quality, and gave us the most satisfaction with the end result. " "The basic circuitry is a very simple discrete single-ended Class A stage designed to operated at low gain and feedback levels with high performance and stability." I am not suggesting an X active filter it is not a brilliant idea on Uli's part. However careful reading of both the Borbely and Pass diy literature regards the classical requirements for active filter buffers and Mr Pass known pre disposition for less is more suggests there may be un realised subjective virtues in the minimalist XVR1 buffer. It would appear the circuit is rather clever, it uses only two stages, (like the Aleph) has very low noise, very low distortion and low gain with low feeback while the full balanced output topology cancels all common mode noise/distortion. Surely if full complementry, cascoding or whatever was a subjective a benefit it would have found its way into the final design. The practical implementation is certainly straight forward. Has anyone considered or trialed this buffer with a breadboard or done any simulations at this stage? Again, I am not attempting to distract from Uli's endeavour, just interested to hear if any of us has combed over the existing circuit model. Maybe the next version of the XVR1 will be XVR1-Xuli. macka |
#89 |
There are a lot of brilliant things going on in Xed circuits.
First of all the count of active gainstages is exactly the same as in similar non X circuits. Example: In Passlabs XVR you got one input buffer consisting of 2 stages next are 2 filterbuffers consisting of 2 stages each and finally the outputbuffer consisting of 2 stages. Total count: 8 X version count: 8 When you X this arrangement the activestagecount stays the same except the outputs of the stages but this is a matter of definition whether to count them as extra active device or not. To Peters hint having a 12dB slope with just one pole. Mathematically this is not logical so I will try to explain why. (Please forive my lacking of writing art, Grey is the hero for that.) Imagine a floating balanced input for example a Xfmr. It simply doesn´t matter if you couple one of the input nodes via 10µF and the other node directly or couple both of them with two caps 20µF (!) each as they are in series electrically. Maybe Peter misinterpreted the resulting one octave higher hipass frequency as 12dB. This result you get when you couple two times 10µF instead of 20. Back to XXover circuitry: You definitely double the filter components like caps and resistors but I consider this not as doubling in the signal path since they work "antiparallel" (out of phase) In implementing such circuitry you have the problem to intrinsic matching at least the caps in the circuit whereas the resistors can be chosen 0,1% which is recommended when using the values shown in an older post. To be continued..... Uli
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#90 |
Very interesting thanks Uli,
Well we may well have a Diy XVR1 -Xuli on the drawing board, Sounds great. macka
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Need High level, high pass crossover for 250watts | Anthrax | Multi-Way | 0 | 21st January 2007 03:34 AM |
| high gain 2nd order high pass active filter topology | sreten | Solid State | 21 | 23rd March 2006 01:26 AM |
| variable Low-Cut, High-Pass & High-Cuts | TobWen | Solid State | 3 | 14th September 2004 09:40 PM |
| Page generated in 0.19346 seconds (72.35% PHP - 27.65% MySQL) with 11 queries |
