AB100 Class AB Power Amplifier - Page 7 - diyAudio
Old 13th January 2013, 09:33 PM   #61
Loudthud's Avatar
The missing ground should be at the C5, R35, R8 node just like the A40. Like Antoinel says, it's a bootstrap input to increase the input impedance.
Old 29th January 2013, 10:14 PM   #62
Loudthud's Avatar
Nelson, any words of wisdom on how to bias this thing? Also, why the 22 ohm resisitors on the base of each output transistor? Current sharing, stability, artistic license?
Old 30th January 2013, 03:14 AM   #63
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
they're 220R resistors
you can call them artistic stability supporters
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th January 2013, 04:37 PM   #64
The one and only
Nelson Pass's Avatar
Originally Posted by Nelson Pass View Post
Also note that resistors are XXX plus multiplier: 1001 is 1K.
I like to quote myself. I find it elevates the tone of my conversation.
Old 30th January 2013, 05:16 PM   #65
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
Watch out Papa, this is already the first signs of a cult of personality.
Anyway, thanks for the clarification.
Gyuri
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 30th January 2013, 06:09 PM   #66
Loudthud's Avatar
So a 221 ohm resistor should be 2210 like R10.
I'm finding that collector current needs to be about 50mA per transistor to smooth out the crossover region.
Old 2nd February 2013, 10:10 PM   #67
AB100 Amplifier - Micro Article by Nelson Pass
Since villagers armed with pitchforks and torches have begun camping out my front door demanding a Class AB power amplifier,
and Whereas, I am inclined to demonstrate my goodwill in this manner and do in fact have a 13 year old piece laying around unpublished
So it will be any article about AB100 published at "articles section" on FIRST WATT or Pass DIY?
Old 2nd February 2013, 11:16 PM   #68
Zen Mod's Avatar
221 = 22 x 10^1 = 22 x 10 = 220
or , just read them as 221R resistors
Old 3rd February 2013, 12:06 AM   #69
The one and only
You saw it already. It was a uArticle
Old 6th February 2013, 03:23 PM   #70
Braun_ is offline Braun_  Brazil
Basic question. The original design produces 100W@8Ohms with 4 output pairs. If I want less power, around 25 to 50W, Can I just reduce the numbers of output transistors?
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets opc Solid State 2583 7th April 2017 09:52 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
It helps to select best class power amplifier (AB- 40-50 watts) lopezm0 Solid State 59 16th December 2012 04:13 PM
DIY Low Power Class A (or AB) amplifier suggestions gareth Solid State 2 16th June 2009 02:46 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 08:12 PM
Copyright 1999-2017 diyAudio
