AB100 Class AB Power Amplifier
Old 7th July 2014, 07:06 PM   #141
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
two facts :
- sch was prepared for commercial project
-Pa published it here
what else ?
maybe stick to someone's bum ...........
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 7th July 2014, 07:42 PM   #142
Bigun is offline Bigun  Canada
Bigun's Avatar
What
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 7th July 2014, 07:43 PM   #143
Loudthud is offline Loudthud  United States
Loudthud's Avatar
The A40 uses Darlingtons and a very similar front end.
Old 7th July 2014, 09:06 PM   #144
Bigun's Avatar
ah !
Old 7th July 2014, 09:47 PM   #145
east electronics is offline east electronics  Greece
east electronics's Avatar
I only made one A40 only for testing and learning from
Even though what i made was a crappy job and kitchen table style with almost poor choice of parts the A40 was a solid rock and free from many of known problems existing in consumer amps that feature one pair of Darlingtons that tent to blow very easily .
To advance this a bit farther i will have to include the A40 in the world wide unique output stages since A40 is the only amp ( that i know ) that has multiple Darlingtons in the output .
In the same family ( and world wide unique )you have the Alchemist Forseti which is a CFP with double the CFP thing on the output with in total 4 outputs with 4 drivers per CH .It is known that APD 15 run into stability probs and band aids of 680 pf had to be placed in the output to prevent blowing .
In the same family you Have Nakamichi PA 7 Stasis from NP which also is unique since features CFP output but with many external transistors (10 i think ) also solid rock extremely reliable ( except some soldering issues but this will happen after 30 years !!! ) that also playes very well and has no band aids in the outputs .
Now Do the math why consumer amplifiers with darlingtons fail all the time??? Anythings that is based on TIP 142-147 or BDV 66-67 will eventually fail ..Denon Philps red circuits Kapibara The Notorious John Fisher sorry excuse of an amplifier with catchy title and many more fail like mosquitoes.... Not to forget latest techniques with SAP 15 working just a bit better but still with a huge history of failure .
Why APD 15 run in to stability problems ???
What is common between the A40 stability and the NAk PA7 stability ?
One and only thing called Bias !!!
Run them HOT and they are going to be stable !!
...This is what i think .. I would like to have NP's opinion on that
Kind regards
Sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 8th July 2014, 11:26 AM   #146
R.I.P.
Originally Posted by Loudthud View Post
The A40 uses Darlingtons ...............
Darlington?
or double EF?
regards Andrew T.
Old 8th July 2014, 11:37 AM   #147
Double Darlington transistors Andrew in EF configuration
That in a way is common with the Alchemist since its world wide unique and features 4 outputs and 4 drivers per ch
Kind regards
Sakis
Old 8th July 2014, 11:42 AM   #148
R.I.P.
What's a Double Darlington?
An IC with four transistors inside?
regards Andrew T.
Old 8th July 2014, 12:02 PM   #149
Andrew get your self a cup of coffee and a schematic
The A40 features 2X TIP142 and 2XTIP147 in the output stage that makes 4 transistors in the output that inside of them include 4 drivers ...
Old 8th July 2014, 07:28 PM   #150
Bigun's Avatar
I am sorely tempted to spin up a pcb, amp-camp style, for a power Darlington output designed to be run in Class AB as I can see myself making use of it.
AB100 Class AB Power AmplifierHide this!Advertise here!
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets opc Solid State 2614 24th July 2017 03:37 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
It helps to select best class power amplifier (AB- 40-50 watts) lopezm0 Solid State 59 16th December 2012 04:13 PM
DIY Low Power Class A (or AB) amplifier suggestions gareth Solid State 2 16th June 2009 02:46 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 08:12 PM
