AB100 Class AB Power Amplifier - Page 13 - diyAudio
Old 12th May 2013, 12:19 PM   #121
Mooly's Avatar
I've moved the Vellemann discussion here to Sakis' thread here,
http://www.diyaudio.com/forums/solid...ml#post3487303
If you want a new thread starting for it then just say so
Installing and using LTspice IV. From beginner to advanced.
Old 12th May 2013, 12:34 PM   #122
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
and maybe MJE340/MJE350 replacing 2SA1110/2SC2590
Originally Posted by tinitus View Post
ZTX450/550 'replacement' might be BC546/556
Old 12th May 2013, 02:16 PM   #123
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Default PASS AB100 - Minimalist improved schematic
Feel free folks to adopt...
Resistance values are now in more familiar coding.
The "missing ground" has been added.
Crossing lines have been 'broken-gapped' for clarity.
Zener has a Vz value.
No adjustments made to actual values.
Subtle... but a bunch easier to "stare at". And that darn input ground insertion prevents the old-timer's "where the heck is the operating point of the zener?" problem.
GoatGuy
Old 12th May 2013, 02:35 PM   #124
Zero Cool's Avatar
GoatGuy
Now if you could add the values to Tinnitus's drawing it would be even easier to read!
It's not about what you can BUY...It's about what you can BUILD!
Old 12th May 2013, 02:55 PM   #125
GoatGuy's Avatar
WHICH tinnitus drawing? He's come up with 2 or more.
Its funny - maybe 'cuz I live in The Colonies (AKA America) - but I get weird feelings when I look at resistors, drawn correctly by IEEE and EU standards, as little square boxes, instead of zigzags. Every OTHER component in electronics is a symbolic representation of its "principle of action". Capacitors are separated plates, transistors are bases with emitter and collector points touching (like Schottky's original!), diodes are symbolic "electrons stop here", coils look ... like formalized coils. Transformers are obvious, even tubes are pretty clear. Switches - bars that switch, etc.
Well, "resistors" are accurately zigzags! Originally almost all wire-wrapped, the notion is, "a bunch of crumpled up conductor, thin, that gives resistance". By comparison, the square box is ... counter to all the other symbols. According to many sources, it was adopted in the 1970s because "it is easier to draw both for draughtsmen and early memory-limited computers". It hardly seems appropriate. The zigzag IS the correct representation, and the little white box ... just "lies": many little boxes in digital electronics especially harbor marvelous and obscure functionality. Indeed, one does a disservice to a digital circuit schematic of any complexity using little square boxes for pull-up or balancing resistors.
This is why I'm also not inclined to annotate Tinnitus's drawing. Call me provincial, but I think Nelson Pass's original AD2000 drawing (with broken gap crossovers) is entirely clear. And I like zigzags for poor conductors. Gotta make those electrons run, run, run! That way they get tired.
GoatGuy
Old 12th May 2013, 03:08 PM   #126
so that my drawing remains worthless, and not floats around the net with wrong values or text, I have intentionally stayed away from adding any kind of values, or text
but feel free to print it out and use for your own personal use
I hope thats ok, and clear enough
same goes for the resistor chart, no text added
use as you wish
but please refer to original schematic for correct values
Old 12th May 2013, 03:20 PM   #127
well, for that you deserve at least 'something'
I guess component numbers will be ok
btw, since bias transistor Q8 is a TO-92, Im planning a small board for it
it will be mounted with small alu plate with hole for the transistor
the hole bias curcuit can then be mounted on the main heatsink
drawing will come soon, ofcourse
Old 13th May 2013, 01:48 PM   #128
MJE340/350 does not appear to be very popular
but I have a few 2SC5171/2SA1930...maybe they would do ok
maybe, maybe not
getting tired
final...but still needs careful checking
File Type: gif Pass AB100 print layout work rework 3.gif (34.8 KB, 672 views)
Old 15th May 2013, 04:49 PM   #129
east electronics's Avatar
Tinitus ...I offered again to give you a free copy of layout software ...Offer is still on !!
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 15th May 2013, 08:05 PM   #130
producing boards....sounds like fun
but I better leave that to others
Im even more hopeless with computer software
but thanks anyway
just small cosmetic change
File Type: gif Pass AB100 print layout work rework 4.gif (34.2 KB, 413 views)
File Type: gif Pass AB100 print layout work rework 6.gif (34.4 KB, 352 views)
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets opc Solid State 2553 22nd February 2017 10:34 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 09:52 PM
It helps to select best class power amplifier (AB- 40-50 watts) lopezm0 Solid State 59 16th December 2012 05:13 PM
DIY Low Power Class A (or AB) amplifier suggestions gareth Solid State 2 16th June 2009 03:46 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 09:12 PM
Copyright 1999-2017 diyAudio
