AB100 Class AB Power Amplifier
Old 10th May 2013, 10:13 PM   #111
Loudthud is offline Loudthud  United States
Loudthud's Avatar
See attached.
Old 11th May 2013, 07:27 AM   #112
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
ahh, there it is, the missing grounding.....thanks!
and now... the resistors
Old 11th May 2013, 08:19 AM   #113
are these values correctly 'interpreted' ?
edit...R2 and R4 hanged, and I hope correct now
is P1 really only 500ohm, or is it 5k ?
Old 11th May 2013, 10:28 AM   #114
AudioSan is offline AudioSan  Norway
R2=22.1K, R4= 22.1K, R6=33.1, R8-9=4,75K, R13=68.1, R14= 6.81K, R15= 1.5K, R15-16=10.1, R34=3.3.
Old 11th May 2013, 12:35 PM   #115
R14 corrected....
thanks!
Old 11th May 2013, 01:06 PM   #116
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
wouldn't we want to add a bypass cap across C5/6 and Z1??
It's not about what you can BUY...It's about what you can BUILD!
Old 11th May 2013, 04:18 PM   #117
for 'convenience', and layout, my usual exercise....drawing to get 'familiar' with the components ....and I hope its still the same amp
Old 11th May 2013, 04:52 PM   #118
east electronics is offline east electronics  Greece
east electronics's Avatar
I will have to presume that the diode string across the bases of TIP 142 147 will shunt excessive drive to output and that will create a crude method of limiting if and when needed
I am actually not familiar how protection like that will work sound wise ...None of the amplifiers i am listening to had this schema of protection ...Also don't know how effective this is
Then the question for me is :why bother? since Darlingtons on the output will do there "own" thing after the protection depending on the thermals cooling load and so on and on .
Tinitus i think exercise is always nice and sharpens brains but i think one may put his energy on a pcb and not a schematic .
Nice idea for a weekend project could be a pcb that has the arrangement of transistors L style bracket made like NPNPDVBEDNPNP
Where
N stands for NPN
P stands for PNP
D for driver ( there can be a question if driver needs common heat sink with outs)
and VBE will be Vbe
could be nice project but not for me ...unless one has a better darlington to offer than 142 147 ( any with audio specs will do )
I presume that arrangement like that will offer excellent current sharing and equalize thermals all the way through . Point is no matter what i say the next step is to construct and listen cause i may hate darlingtons while NP operates them in an ""other" way and after all may worth listening .
Kind regards
Sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 11th May 2013, 06:35 PM   #119
Originally Posted by Nelson Pass View Post
A few quick answers.
The original design (this one) was intended for dummies with maximum
reliability and minimum adjustment and also minimum opportunity for
noises and pops. ....
I guess that answers it .... maximum reliabity sounds good for my bass guitar... and intended for dummies, spot on too
I expect to hardwire on proto board
regarding the Darlingtons
with their high current gain, I suppose they are easy to drive, and might have been chosen for that reason ?
http://www.onsemi.com/pub_link/Collateral/TIP140-D.PDF
I guess there is a first time for everything, also on Pass forum
Old 12th May 2013, 09:53 AM   #120
ZTX450/550 'replacement' might be BC546/556
AB100 Class AB Power AmplifierHide this!Advertise here!
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets opc Solid State 2614 24th July 2017 03:37 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
It helps to select best class power amplifier (AB- 40-50 watts) lopezm0 Solid State 59 16th December 2012 04:13 PM
DIY Low Power Class A (or AB) amplifier suggestions gareth Solid State 2 16th June 2009 02:46 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 08:12 PM
