AB100 Class AB Power Amplifier
Old 9th May 2013, 08:15 PM   #101
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Antoinel View Post
Please see the thread "Bridge a pair F5s" for more detail.
ah...for bridging two stereo amps, I guess
but starting from scratch, I thought 'X-balanced' would be better
well, maybe its better to go slow on the balanced subject...its still early days for this thread and it might go on for a long time
Old 9th May 2013, 08:37 PM   #102
Antoinel is offline Antoinel  United States
I'll pause for the time being and wait to explain its operation.
Old 9th May 2013, 08:53 PM   #103
well, in any case, before going balanced for real, we need a working amp, at least
Old 9th May 2013, 09:04 PM   #104
back to sorting out the transistors ?
Old 9th May 2013, 09:59 PM   #105
Two threads already explain [by analogy] the operation of Conjoined Twin AB100. They are "Conjoined Twin DiyF6s" and "Bridge a pair of F5s" in the Pass Labs Forum.
Best regards.
Old 10th May 2013, 01:34 AM   #106
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Originally Posted by Nelson Pass View Post
I should think they would do the job, and fewer of them.. Of course you
don't at all have to use darlingtons. It's trivial to put together a driver stage.
Trivial for YOU maybe LOL!
Not so much for us Padawans!
It's not about what you can BUY...It's about what you can BUILD!
Old 10th May 2013, 11:16 AM   #107
I hope this is ok...
Old 10th May 2013, 11:18 AM   #108
Zero Cool's Avatar
Diode Z1 is missing in your drawing!
Old 10th May 2013, 11:25 AM   #109
its there now
seems like the darlington TO-247 is no problem at all
Old 10th May 2013, 09:19 PM   #110
hopefully not too many errors
AB100 Class AB Power AmplifierHide this!Advertise here!
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets opc Solid State 2614 24th July 2017 03:37 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
It helps to select best class power amplifier (AB- 40-50 watts) lopezm0 Solid State 59 16th December 2012 04:13 PM
DIY Low Power Class A (or AB) amplifier suggestions gareth Solid State 2 16th June 2009 02:46 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 08:12 PM
