An illustrated guide for Aleph 60 builders
Old 1st April 2013, 06:11 PM   #31
generg is offline generg  Germany
generg's Avatar
sorry....had hum in the brain....
and the First Wtt is......a really First Class PSS Idea
Old 1st April 2013, 06:50 PM   #32
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Its BUZZZZZZZZZZZZZZZZZZZZZZZ!
...Shape the sound , Man!
Old 29th August 2013, 07:45 AM   #33
Danger Mouse is offline Danger Mouse  Germany
Danger Mouse's Avatar
Hello
After solving hum problem at my aleph J i going to plan my next project
a Aleph 60.
Because of limited space in the chassis i dont get the trafos in the front of the chassis side by side
Now i have 2 options:
1. to staple the trafos in the front of the amp
with stapled psu in the rear part
2. trafos side by side from front to rear with psu on top
-in both cases the input is on top in the rear part of the amp
-the picture should be a view from the side
I dont want pick up hum from the trafos in the input stage,
which one would be the better solution?
thanks for suggestion
Old 30th August 2013, 02:52 AM   #34
PKI is offline PKI  United States
PKI's Avatar
I would pick option 1 with two trafos stack on a top. However, I've seen many people do PSU right above the transformer.
Old 30th August 2013, 07:49 PM   #35
Thanks, i also think first variant will be the preverred.
I`ve seen var. 2 at a f5 turbo somewhere, it seems working also.
But i really dont trust that the trannys will not stray into input stage.
I`ve heard that in the middleaxis of a tranny the magnetic field will be strongest.
And this will be in var.2 with the PSU between direct under the input stage.
Old 30th August 2013, 08:14 PM   #36
PKI's Avatar
About dance packing inside enclosures: look at first cubical alephs :-)
Old 31st August 2013, 09:07 PM   #37
Originally Posted by PKI View Post
Just installed IRF9610 in the FE of my Aleph's. I have to admit, for my taste these transistors suit the amp's sound much better!
Thanks, h_a! ;-)
The IRF9610 came from Vishay IR or someone else?
Old 31st August 2013, 09:39 PM   #38
did you chew on conversion to cascoded Jfet FE ?
I did...
...and i found this Jfet input for Aleph 60?
but i also think about to use a cascode like in the f5 turbo v3 (Q7,Q8)
and use the standart Aleph J frontend with double the 2sj74 (4matched jfet)
could this work?
Variant from Zen looks also good but i dont understand what he did
Old 31st August 2013, 10:11 PM   #39
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
is there a question ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...Đ by Mighty ZM
Old 31st August 2013, 10:13 PM   #40
6L6 is offline 6L6  United States
6L6's Avatar
I don't think the links work properly...
An illustrated guide for Aleph 60 buildersHide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 986 29th July 2017 06:20 AM
Horn builders tool - diy rip fence/guide quadtech Full Range 9 9th May 2009 07:23 PM
The definitive Sachiko builders guide quadtech Full Range 2 4th February 2009 07:21 PM
Aleph X builders, these might be the right caps for you Peter Daniel Swap Meet 27 9th October 2003 06:22 PM
Aleph-X builders in Sweden? Pan Pass Labs 0 29th December 2002 05:28 PM
