My Blanced Line stage pre amp - Page 2 - diyAudio
Old 15th November 2003, 01:19 AM   #11
Very nice job but those LED's are an insult to the master....... PLus the blue LED's do sound better.
Mark
Old 15th November 2003, 05:31 AM   #12
macka's Avatar
Hey Andy,
Cool layout and nice presentation.
If I am not mistaken, is that the relay input board from audiomania Pass Balanced line stage.
http://www.diymania.net/
I used the same design for my BOSOZ. It works very well!
macka
Old 15th November 2003, 08:32 AM   #13
Default use volume control by ALPS 5K Blue velvet
also i use relay board from www.diymania.net
and it works very well
i am connected input line directly and master volume used
alps 5k bluevelvet, just out-line
All FETS and resistor are very very hot..i can't touch more 3 second
BOSOZ SOUND IS REALLY REALLY EXELENT!!!!!!!!!!!!!!!!!!
Old 15th November 2003, 10:30 AM   #14
PsykoK is offline PsykoK  France
Send a message via ICQ to PsykoK Send a message via AIM to PsykoK
Nice work!!
I use this relay Board too for the output selection, it's a good choice
Some pics:
Relay Board 1
Realy Board 2
Old 16th November 2003, 04:10 AM   #15
Default bzls testing?
Andy:
I also finished my BZLS and have completed the boards. I blew the board once, because the wrong connection. Now, I have fixed the boards. I have my PSU output to +/-60V, but how do you test the main board w/o connecting the wire?
I use the multimeter to measure, the only problem is that Z1, Z2 in both channels have different resistance value (R ch is 3 times higher than L ch). Is this the right way to test it this way?
Can you post the details photos of all the boards (or zip it up for us to download)?
Thomas
Old 16th November 2003, 08:08 AM   #16
Default detail photo
hi..tomchaoda
I was made 100% same pcb work to Pass diy project from
http://passdiy.com/pdf/balzenpre.pdf
this photo is first version line board.
after i replace some parts ( resistor , capacitor )
FETS and zener diode are same part
My PSU out put to +59 , -60V , but its no matter
i think Z1,Z2 zenor is just protect to input signal
so please check about some resistor and FETs
As a matter of fact i didin't know exactly...^_^
good luck tomchaoda
thanks
Andy
Old 16th November 2003, 12:17 PM   #17
For the selection board see the following thread:
[BOSOZ] PCB fot the Audio input Selection board
Old 18th November 2003, 08:35 AM   #18
Djomil is offline Djomil  Serbia
Congratulations!!!!!
Very nice job, but I have one advice how to upgrade your sound. Use BLUE LED!!!!!!!!
Once again, excellent.
Greetings from Belgrade...
Which DHT for Line stage? andyjevans Tubes / Valves 15 26th March 2009 01:10 PM
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 09:50 PM
Blanced input & output for alesis 3630 Maximo Instruments and Amps 6 7th April 2007 08:47 AM
Looking for a blanced mic preamp Ahmad_tbp Solid State 6 7th February 2007 10:08 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Copyright 1999-2017 diyAudio
