please help me
please help me
Old 31st December 2012, 11:59 AM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
please help me
please think
you said - you have protection circuit implemented on board
so , if I look at Aleph 30 schematic , I can't see schematic of missing part - protection
i have this schematic , collected from somewhere
is it similar - regarding protection ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 31st December 2012, 12:19 PM   #12
vivanco is offline vivanco  Italy
Originally Posted by Zen Mod View Post
please think
the protection circuit I bought from Jims_audio (indicated below the photo), I try to ask him if he can provide me the circuit.(but I think it will be very difficult)
Uploaded with ImageShack.us
Old 31st December 2012, 12:22 PM   #13
Zen Mod's Avatar
please help me
ok - for now just exclude speaker protection ( but do not connect speaker to amp output)
post schematic here , which you're using and familiar with , and I'll mark what to measure
Old 31st December 2012, 12:31 PM   #14
you mean the diagram of the amplifier? If so, the circuit is this:
Pass Aleph 30 Sch original.pdf
Old 31st December 2012, 01:47 PM   #15
Zen Mod's Avatar
please help me
so - download this file , open it in MS Paint or some other graphic editor program , measure all red circle marked voltages in your actual circuit and write them on schmtc
then post it here
do not forget - both inputs grounded while testing
nothing connected to output
disconnect
speaker protection circuit from amplifier for now
Old 31st December 2012, 02:37 PM   #16
my power supply provides 23 volts, so you wonder if the values you have indicated no change;
however, if it can help you, I did a test and that is the extent of the offset : without signal, the measurement is 54mV, while inserting the plug XLR (even with the preamp off) the value increases to 0.54 V
NB: the protection circuit has been removed
Old 31st December 2012, 02:45 PM   #17
Zen Mod's Avatar
please help me
do what I wrote - measure everything with red circle
there must be something - either broken part or wrong wiring
Old 31st December 2012, 03:26 PM   #18
These are the measurements:
on resistor 221ohm 4,88 V (you post 5 V)
on zener 8,64 V (you post 9 V)
on drain IRF9610 (current generator for differential) 3,53 V (you post 4 V)
collector-emettitor ZTX450 UP 3,93 V (you post 4,5 V)
collector-emettitor ZTX450 DOWN 4,27 V (you post 4,5 V)
on first triplet resistor 0,47ohm : 0,40 V - 0,39 V - 0,38 V
on second triplet resistor 0,47ohm : 0,41 V - 0,38 V - 0,38 V
Old 31st December 2012, 03:49 PM   #19
however, the thing that continues to leave me perplexed the fact remains that if not connect the signal, the output voltage is around 40mV, while connecting the signal rises to 0.54 V, hence the reason for which the speaker protection (which currently is disconnected) goes in protection.
Old 31st December 2012, 04:48 PM   #20
Zen Mod's Avatar
please help me
so , after several posts - I'm realizing that your problem is combined from two things :
1-unmatched input mosfets
2-missing procedure/possibility for setting output offset
cure :
replace R11 with 500R multiturn trimpot (connected as variable resistor - middle leg connected with one (any) outer leg)
set it , prior to soldering , to half value
short both inputs to ground
power up
set offset with that trimpot , after temperature equilibrium
do the same for other channel
shorting inputs to gnd during setting offset and Iq procedure is a must
please help meHide this!Advertise here!
Copyright ©1999-2017 diyAudio
