Old 13th November 2003, 03:23 AM   #1
Default aleph 2 temperature
I was just curious what temperature values people have gotten at the 'hottest spot' on their aleph 2 heatsinks once they reach standard operating temperature.
Thanks Mike
Old 13th November 2003, 03:41 AM   #2
About 105 degrees F, if I remember correctly. That's on the device itself.
Ahem...
Mine are water-cooled. Your mileage will definitely vary.
Grey
Old 13th November 2003, 04:02 AM   #3
Brian Donaldson's Avatar
I have a thermometer tucked in between fins behind a fet with a peice of rag jambed in to help get a acurate reading. running full tilt 52V 5A It'll hit 170 deg f without the fan. Smells funny but sounds great. The pair will raise the room temp about 10 deg. when you walk by them, it's like walking past a fireplace.
Old 14th November 2003, 03:31 AM   #4
Wow! Brian I hope you have a Halon fire extinguisher system right above them. Sounds like its quite possible they may see molten Aleph 2's in China some time in the near future.....
My 2's run at 55 deg. C. with plus and minus 42 volts on the rails and about 4 amps.
Mark
Old 14th November 2003, 03:38 AM   #5
Send a message via AIM to jewilson
Default 170 oF OUCH
Do you own a fire extinguisher
Jim W.
Old 14th November 2003, 03:42 AM   #6
That's the temp with no fan. my finished chassis will have a fan that draws air in the back (to cool innards) and will exaust through a row of holes, one in between each fin to help drop rtheta. The voltage to the fan will be controlled by a neg coef thermister in a voltage divider that will drive a source follower so fan speed can track temp. I still need to play with this circuit to be sure the the speed doesn't overshoot and turn off and on. With the huge thermal mass and slow ramp up from stop to full, It should settle on a speed.
When I was doing my stress test, I had the surge protectors switch near by.
Old 14th November 2003, 03:53 AM   #7
Hey Brian,
Route the hot air output from them into your heating ducts! Toss the thermistor and just hook the fan to your house thermostat . Money spent on electricity will be saved on gas. The water cooled Aleph dudes can heat water for the hot tub instead. Gee the economic consiquences of owning an Aleph might actually be pretty positive. Comming soon, Mr Aleph Coffee Maker brewing full High Fidelity Coffee!
Lets see a Krell pull off any of these feats. Well ok, they could if you're into drinking ice coffee I guess.
Mark
Old 14th November 2003, 04:07 AM   #8
Default Aleph's and Fans
Brain,
The fan speed control sound nice, but shouldn't you just set it to max.
Jim W.
Old 14th November 2003, 06:25 AM   #9
jleaman is offline jleaman  Canada
Send a message via AIM to jleaman Send a message via MSN to jleaman Send a message via Skype™ to jleaman
Im putting a fan on mine also just a small one to move the air inside around to keep the inards cooler. i dont want a fire. : O ) Small fan running at 3v will more air slowly and quietly enough..
Baby Danika, Born January 20th 1:54am..
http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect..
Old 14th November 2003, 07:52 AM   #10
Nickolas K.'s Avatar
Default Brain
Have you ever considered getting yourself somethink like this?
Is this phase one of Lumpy Gravy?
Aleph X - mosfet temperature yoke Pass Labs 48 16th December 2006 06:06 PM
operating temperature for Aleph Phill Pass Labs 9 22nd November 2005 01:06 AM
help: Aleph x temperature sensitive Berry Pass Labs 11 10th October 2005 06:47 PM
Aleph Temperature Sweet Spot macka Pass Labs 12 21st March 2002 11:39 AM
Page generated in 0.10070 seconds (80.53% PHP - 19.47% MySQL) with 11 queries
