F3 mono blocks
F3 mono blocks
Old 30th December 2012, 10:39 PM   #21
generg is offline generg  Germany
generg's Avatar
F3 mono blocks
You should really look for a sound card solution to measure distortion.... No money!
Look if the sound card does 24bit and 48KHz.....
Use ARTA for windows
If you are Mac user use a thirty day demo of Electroacoustic toolbox....
To have prober wiring from amp to sound card PM me.....
More fun ....... And I am afraid nobody will know much more than Nelson, ZM and all the others said here.....
and the First Wtt is......a really First Class PSS Idea
Old 31st December 2012, 12:43 AM   #22
yup is offline yup
Default Wow
Thanks everyone for the tremendous response!
Nelson,
Thank you. Yes I went through the Idss exercise. The jfets are both 1.027 Vgs and I am currently using a 1.5ohm resistor for R3 (ZV9 schematic)
I am embarrassed to say that these jfets are from the original GRollins group buy Wow, I'm slow... The lot code from the jfets are all 0540G. I imagine that there are a lot of people with this same lot code jfet in functioning amps. FYI, all of my IRFP244 devices that I am using have a Vgs of approximately 4.44V
Zen Mod and Dzius both suggest that increasing bias should improve things, so I guess it won't hurt to change R8 (F3 schematic) back to 1ohm (from 2ohm - F3 schematic) to increase the bias to 2A and see what happens to the voltage across the jfet and the gain. I'll report back tomorrow and let you know what happens.
Generg,
I will send you a PM about using ARTA to measure distortion. I have actually been looking at this since I have been thinking about an active crossover to use with these new F3's and my Aleph-X. If I can use it to help with this then that would be great!
Old 31st December 2012, 03:48 AM   #23
BDP is offline BDP  United States
Maybe this will help
http://www.diyaudio.com/forums/pass-...ing-one-9.html
Old 31st December 2012, 02:08 PM   #24
yup is offline yup
Originally Posted by BDP View Post
Thanks BDP, that helps me feel a little better about the voltages I am seeing. Looks like performance will be good within a fairly wide range.
Can you hear a difference between the ZV9 and the F3 with the different bias currents?
Old 31st December 2012, 07:59 PM   #25
yup is offline yup
Default Updated voltages at 2A bias current
I increased the bias current to 2A and let the amp warm up for several hours. I have attached the schematic with the new voltages. Interestingly, the jfet now has about 2.6v across it. What a big difference a little more bias current makes. The hottest spot on my heat sink is 125F directly underneath Q3. Overall, the heat sinks are about 100F, but my shop is a little cooler than my living room will be.
I was able to increase the gain to 14.5db within the range of P2
I put dip switches on this board for both feedback and the Aleph current source so I can play around with turning those on and off. This should come in handy for setting the ACS.
With a 1Vpp sine wave input, I measure 2.65Vpp output with the ACS off (8.5db). Just to confirm, I should adjust P2 to give 5.3Vpp at 1Vpp input (14.5db) to achieve 50% gain via the ACS? Or to 4.3Vpp to achieve 12.75db (commercial F3)?
I will continue to try to try to find a way to measure the distortion at some point to do some final adjustments. And a lot of listening
Now on to the next issue, the square wave response...
On the scope the bottom trace is the input at 0.5v/d and the top trace is the output across an 8ohm resistor at 2.0v/d.
The first image is at 1kHz and the second image is at 10kHz
Anyone care to guess what is going on or what I should look at? I tried a 50ohm resistor across the amp input and without - no significant change.
Old 31st December 2012, 08:02 PM   #26
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F3 mono blocks
fiddle with C9
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 1st January 2013, 09:26 PM   #27
yup is offline yup
Well, I fiddled with C9 and then removed it completely, but it didn't improve the square wave response.
I tested a different amp I have to be sure something wasn't wrong with my test setup and it worked fine at both 1kHz & 10kHz (actually it had a slight ringing on the leading edge).
I tested the amp with the feedback dip switch turned off completely. The bottom trace is the sine wave input at 0.5v/d and the top trace is the output across an 8ohm resistor at 5.0v/d (clipping with signal generator at minimum output)
I have C7 (F3 schematic) in circuit, but I don't currently have R22 or LED1 in circuit. Could this cause this type of issue with the square wave?
Old 1st January 2013, 10:17 PM   #28
Zen Mod's Avatar
F3 mono blocks
gate resistors ditto at gate's pins ?
Old 1st January 2013, 10:28 PM   #29
yup is offline yup
Zen Mod,
Yes, I moved the gate resistors off board for Q2 & Q3. They are actually soldered directly to the transistors since they are mounted on the side heat sinks about 8 or 9 inches away from the board.
Old 1st January 2013, 10:42 PM   #30
Zen Mod's Avatar
F3 mono blocks
increasing C9?
F3 mono blocksHide this!Advertise here!
Dartzeel mono blocks. Bonsai Everything Else 25 7th November 2012 12:31 AM
now mono blocks! ksporry Tubes / Valves 0 5th February 2011 08:32 AM
Grounding When Doing Mono Blocks jawbreak Chip Amps 5 5th September 2007 09:46 PM
100watt mono blocks yise1 Tubes / Valves 2 27th August 2006 06:29 AM
Bridging Mono Blocks jwatts Tubes / Valves 8 12th February 2005 08:23 PM
