My F4 Build - Page 6 - diyAudio
Old 11th March 2013, 09:57 AM   #51
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
caps with hot glue .......
solution good for prototyping , but not for permanent use
both clumsy and unsafe
use some veroboard + wire or raw pcb material , and exacto knife to form traces ( in that case - more fields than traces )
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th March 2013, 12:02 PM   #52
Einric is offline Einric  United States
Einric's Avatar
I had thought about using PerfBoard and just running bare 16awg solid I have.
Old 11th March 2013, 12:15 PM   #53
Zen Mod's Avatar
yup
Perfboard = veroboard ( this side of big splash)
Old 12th March 2013, 07:30 PM   #54
6L6 is offline 6L6  United States
6L6's Avatar
200va is too small for stereo. Get two or wait for bigger ones to arrive.
Old 12th March 2013, 11:00 PM   #55
Einric's Avatar
I will stick to the 300VA.
Old 18th March 2013, 01:26 AM   #56
The Space Egg Corp's Avatar
I stuck to a 300VA once...
...but was using 'super-glue' not hot-glue.
Mmmm...
Cheers
Si.
( nice one Einric ! )
Old 9th June 2013, 10:54 PM   #57
Einric's Avatar
Alright, The ball is rolling once again.
I was thinking since I will be force cooling this amp should I use a 400VA transformer so I can have more overhead on the bias?
Or will the 300VA Antek be suitable up to 400mV bias?
I know the build guide shows 300mV being the "Sweet Spot" but with forced cooling I should have more bias ability.
I will be ordering all the P/S parts in the next few hours, HAPPY FATHERS DAY TO ME!!!!
Old 9th June 2013, 11:30 PM   #58
6L6's Avatar
400mv =.4
Across a .47ohm is (.4V/.47R) = 0.85A per device,
With 23V rails .85*23 = 19.6Watts per device.
19.6*12 = 234W of standing bias. That's quite a bit to ask from a 300VA transformer. (And awfully hot as well...)
Use a 400VA.
Also, the distortion gains when biased past 300mV were very small compared to the current required. However, if you have the power and heatsinks, by all means try it.
Old 9th June 2013, 11:38 PM   #59
Einric's Avatar
Sweet! 6L6 you have always been a valued source of insight.
400VA it is, The size is only .1" larger so it shouldn't cause any space issues.
I will order the AS-4218 as soon as supper is over.
Old 9th June 2013, 11:40 PM   #60
6L6's Avatar
The AS- series is fantastic, they are shielded, which is totally worth the extra ten bucks.
I have two sitting on a shelf waiting for a special project. (I don't know what yet...)
Between F4 and F5 Joshua_G Pass Labs 28 26th November 2011 11:41 PM
Sharing my build progress of the F4 and Aleph 30 eeyore Pass Labs 2 9th May 2011 12:42 AM
first watt f4 help me!!!! mosfet1 Pass Labs 2 18th May 2008 06:44 AM
Any F4 PCBs left for a new wanna-build-one? giacomo_pagani Pass Labs 8 12th May 2008 11:06 PM
F4 and DAC? Flecko Pass Labs 9 23rd February 2008 09:57 PM
Copyright 1999-2017 diyAudio
