My F4 Build - Page 16 - diyAudio
Old 20th July 2013, 08:49 PM   #151
Einric is offline Einric  United States
Einric's Avatar
I'm using Fairchild GBPC3506.
I don't see how it is sag.
My traffo is at 18.3V, that is well within specs and I'm only losing .6V through the CRC.
Since this is all Class A and these are idle readings I just don't see the sag anywhere outside the rectifiers.
Is it possible I have bad rectifiers?
Old 20th July 2013, 08:50 PM   #152
Einric's Avatar
Gyuri...what is your total current?
It only looks like I'm 1V behind you and I'm very heavily biased (@350mV) for an F4.
Old 20th July 2013, 09:00 PM   #153
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
Wait a minute, I must measure it before.
My trafo is said to be 750VA.
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 20th July 2013, 09:04 PM   #154
Einric's Avatar
My 12 FET's are pulling 9A.
All in all though I don't think I'm far enough off to worry about this.
I guess so long as I don't swing to the rails I will be fine.
Old 20th July 2013, 09:05 PM   #155
Gyuri's Avatar
For a single supply line it is at about 1,6A
Old 20th July 2013, 09:07 PM   #156
Gyuri's Avatar
I also thinks so.
Old 20th July 2013, 09:27 PM   #157
buzzforb's Avatar
18.3V x 1.3 for Class A, yields about 23.5V. Figure in a small amount for drop across CRC and I would bet difference is due to transformer. Antes have shown in some threads slightly more sag. Either way, it should not be a big deal if its not leading to noisey PSU.
...Shape the sound , Man!
Old 20th July 2013, 09:40 PM   #158
Einric's Avatar
Nope, This thing is just WONDERFUL.
I just upped the bias from 300 to 350mV just for kicks.
My highest middle pin temp is only 51C, my fans are doing a fantastic job keeping this thing cool.
I have finally gotten a hold of some 14V Zeners to run each pair of fans from, they are inaudible from 3ft. away.
Old 20th July 2013, 09:59 PM   #159
Triodethom's Avatar
Some what low by data sheet. the bridge should have about 1 to 1.1 volt drop at 12 amps . Thus 18.3 (secondary voltage) times 1.404( square root of 2 to figure peak to rms ) about 25.7 minus 1.1 (forward voltage drop) is about 24.6 approx .
Old 8th August 2013, 10:17 PM   #160
The Space Egg Corp's Avatar
Hi Einric
Thanks for the nice PM !
I have been off the air for a while ...
... but gettin' back into things now.
Nice to hear you like the build & it all went well.
C O O L !
Si.
Between F4 and F5 Joshua_G Pass Labs 28 27th November 2011 12:41 AM
Sharing my build progress of the F4 and Aleph 30 eeyore Pass Labs 2 9th May 2011 01:42 AM
first watt f4 help me!!!! mosfet1 Pass Labs 2 18th May 2008 07:44 AM
Any F4 PCBs left for a new wanna-build-one? giacomo_pagani Pass Labs 8 13th May 2008 12:06 AM
F4 and DAC? Flecko Pass Labs 9 23rd February 2008 10:57 PM
Copyright 1999-2017 diyAudio
