Heatsinks from Surplus Store for J2 or F6
Old 26th December 2012, 11:25 PM   #1
avincenty is offline avincenty  United States
Default Heatsinks from Surplus Store for J2 or F6
I found these two heatsinks at my local surplus store. But no clue what the rating is on these. Also on order are some Semisouth SJEP120R125 so I need to figure out if these heatsinks are large enough for a stereo amp. I am a tube guy and this is my first try at a diy solid state amp. Thinking either on a J2 or a F6. Hopefully by the looks of them it should be ok for either amp. Is this wishful thinking on my part?
Alfredo
Old 27th December 2012, 12:26 AM   #2
6L6 is offline 6L6  United States
6L6's Avatar
Those will be fine for the amps you are interested in.
Keep calm and carry on.
Post lots of photos!!
Old 27th December 2012, 12:33 AM   #3
flg is offline flg  United States
flg's Avatar
They look great but, Ideally the best way to use them would be to cut them in two vertlcle 6" tall sinks/ch.You always get the best efficeincy without fans etc. when you orient it with verticle fins but unless specifically made for a long configuration (greater space between fins) 6"-8" is all that would be useful with those. I have a similar Fischer model that does 80-90W at about 5.5wx6dx8h.
I might guess you could do about 100-120W without going over 55C on the sink if they were side by side and 6" high. Of coarse YMMV. Maybe there will be a consencus estimate that will get you going
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 27th December 2012, 12:51 AM   #4
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
comparable with this :
( as said - best to cut them and mount vertically , connected with L or plate heat spreader )
or - without cutting - simply make tall amp
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th December 2012, 01:27 AM   #5
Thanks guys. Cutting them may be difficult for me. How about this? V sticking up.
Old 27th December 2012, 02:06 AM   #6
6L6's Avatar
Those heatsinks are made to have natural convection, and with the proper orientation will be able to get rid of some goodly amounts of heat. If not able to cut them, the best would be to build a tall amp. There are some good examples of it around.
Old 27th December 2012, 03:08 AM   #7
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
If you tell a local metal supplier what you need done (cut in half), who knows, they may be able to cut it for a small charge on their stock saw and maybe even clean up the sawcut on a mill, or direct you to a machine shop? Ask around...
A six inch tall amp will be perfect use of them.
Heatsinks from Surplus Store for J2 or F6Hide this!Advertise here!
FirstWatt J2 Blues Pass Labs 1140 19th March 2018 05:27 PM
First Watt J vs. J2 izzy2 Pass Labs 3 31st March 2012 02:38 PM
The Surplus Store Headphone Amp aerius Headphone Systems 4 24th September 2006 04:05 PM
any surplus store in/around chicago? nt diamdiam Parts 1 29th April 2003 03:43 PM
Site for surplus Heatsinks etc colin.hepburn2 Parts 4 3rd March 2003 07:30 PM
