Pearl Phono (original) problems - diyAudio
Old 26th December 2012, 12:53 AM   #1
6L6 is offline 6L6  United States
6L6's Avatar
Default Pearl Phono (original) problems
Here's the skinny - I absentmindedly had my PSU turned on while I was plugging the umbilical and had it not lined up properly and something zapped.
The PSU is fine, and one channel is fine. The bad channel measures ok except by the final gain stage.
Here are the voltages, the good channel is 'G' and the bad is 'B'
The ZTX has already been replaced with a fresh one. (I didn't test it, and am just assuming it works...)
The obvious next course of action is to replace the K389, (with a pair of matched K170's, because, lets face it, K389 are complete unobtanium these days...)
(And I''ve no idea how to unsolder a 7-pin widget cleanly...)
Does anything else seem wrong?
Thanks in advance.
Old 26th December 2012, 01:15 AM   #2
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
check that ZTX trice , same as those two 10K resistors
these two 10K-ers are just voltage divider and you must have there Ub/2 , not some wakoo point something level
desolder 389 with vacuum pump or solder wick
bloody decade long DIY-er - doesn't know how to desolder 7-legged fuse
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 26th December 2012, 02:03 AM   #3
nigelwright7557's Avatar
If the voltage has been connected wrong then I would replace semiconductors and the electrolytic.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 26th December 2012, 02:34 AM   #4
6L6's Avatar
I'm relatively new to solid state and PCB. Most of my projects in the past use toobz. Replacing those active devices is easy!!!!
Old 26th December 2012, 03:09 AM   #5
6L6's Avatar
I had time to check ZTX before running out of time (my workbench is in storage room accessed through toddler's room... it's a small house...)
hFE is good. Measures in the ballpark of other ztx I have on hand.
Resistors measure (in circuit) the same as the other channel.
I'm more confused.
Old 26th December 2012, 03:53 AM   #6
Zen Mod's Avatar
desolder both ZTX and 2SK389
check 389 with Idss test
Old 4th January 2013, 04:20 PM   #7
6L6's Avatar
Ok, I finally had time to fix it...
The K389 was no longer a live parrot --- it is no more, it ceased to be, bereft of life, it rests in peace.
The circuit wasn't drawing current, therefore the measurements higher up the chain were getting strange.
I replaced it with a matched (Idss) pair of K170, and everything measures fine now. Will listen to it next, once it's buttoned back together.
Gentlemen, thank you for your help , it was invaluable.
pearl phono bernification Pass Labs 2 7th February 2006 09:44 PM
Pearl Phono Done (almost) Gregorio Pass Labs 0 16th January 2006 02:42 PM
Pearl problems lumpylipton Pass Labs 57 13th January 2006 04:30 PM
Anyone building a pearl phono soon? mattjk Pass Labs 8 24th March 2005 01:20 AM
pearl phono hsort Pass Labs 5 2nd March 2002 10:26 PM
Copyright 1999-2017 diyAudio
