SIT Startup Problems - What did I miss? - Page 2 - diyAudio
Old 24th December 2012, 12:55 AM   #11
49 - for the 19th time!!!
c2cthomas's Avatar
I suspect a mis-wire - but should there be a connection to R2 and both bridges as indicated by the schematic? Seems to me that would get things warm inna hurry....
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 24th December 2012, 01:10 AM   #12
I think I did mine this way.
Dan
Old 24th December 2012, 01:12 AM   #13
Because it was easy to reach I measured from R1 to ground and got 50VDC.
Dan
Old 24th December 2012, 01:17 AM   #14
More random thoughts and measurements. I have now noticed that as my measured Ids goes up my Vds goes down. Is that correct?
Dan
Old 24th December 2012, 01:35 AM   #15
Blues is offline Blues  United States
Blues's Avatar
Dan,
You should test your power supply section before connecting the power amp section. You can detach at the bulb, at the wiper lead out, and keep the GNDs connected together. You can then measure the 7912 Vgs biasing regulator if it does go from max value to min of -12V by varying P1.
Once you are sure the PS section is okay then you can focus troubleshooting the PA section.
Old 24th December 2012, 01:38 AM   #16
The one and only
Nelson Pass's Avatar
Yes, that is correct.
Old 24th December 2012, 02:12 AM   #17
Originally Posted by Blues View Post
Dan,
Will measuring from point "A" to ground be the right idea?
Dan
Old 24th December 2012, 02:17 AM   #18
Blues's Avatar
Yes that will work...just disconnect at the bulb to PS (removing bulbs from sockets work too) or at Source/GND connection to be sure there is no influence whatsoever. And you can measure main PS unloaded too.
Go Seahawks!!!
Old 24th December 2012, 03:26 AM   #19
RIP
hotrodmaniac's Avatar
Send a message via Skype™ to hotrodmaniac
Dan
1 Possibly have speaker connected to wrong side of c6.
2 speaker open or not grounded to the correct place.
are you measuring with a dvm? The 47,000uf 25V substitution
was too low of voltage may now be bad. With a dvm and the speaker
not loading the amp c6 would probably leak enough to show dc
voltage on both sides of capacitor.
good luck
Jim
Xhotrodder
Old 24th December 2012, 04:09 AM   #20
Dan,
Both bias circuits range from -2.0vdc to -11.9vdc when measured from point "A" to ground. An unloaded main supply measures 57.6VDC at point "B" on both channels. I'm starting to consider a different 'style' of ground connection between my bias circuit and main circuit.
Here's a more accurate schematic.
Dan
SIT-1 and SIT-2 owner manuals Nelson Pass Pass Labs 25 12th September 2012 08:16 PM
Gone for years....so what did I miss? KT Parts 7 27th August 2012 01:55 AM
NCD1 problems: No blue led blinking at startup Thzar Class D 51 13th December 2009 02:42 PM
Who Doesn't Miss Jocko. fdegrove Everything Else 7 24th December 2002 02:34 PM
Copyright 1999-2017 diyAudio
