SIT Startup Problems - What did I miss?
Old 24th December 2012, 12:10 PM   #21
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Everything else is measuring as it should. It's got to be a bad coupling cap.
Old 24th December 2012, 12:38 PM   #22
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
1- I don't see where you stated if a load was connected or not??? there should be at least a 8-10 ohm resistor connected across the speaker terminals. without a load you may see some DC.
2- the output cap could have a lot of leakage. if you are using old caps for the output cap they could be bad but measure ok and work ok for typical power supply use just not as an output coupling cap. for testing you can use just about any cap there. try a 10,000uf or whatever else you have that may be newer.
Zc
It's not about what you can BUY...It's about what you can BUILD!
Old 24th December 2012, 02:23 PM   #23
AudioMaker.Tech
Originally Posted by Zen Mod View Post
bad Pa ;
'twas your blessing
Now, musn't blame Nelson for my omission.
For the sake of others:
If one tests with a dummy load (as one should) the coupling cap discharges rather quickly through the load.
Since speakers don't always like this sort of thing, we use a 100 Ohm or so resistor connected from the output to ground to bleed off the cap when there's no load connected. This can potentially save you or your speker from a shock.
Old 24th December 2012, 02:41 PM   #24
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
why not ....... I'm really enjoying in that
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 26th December 2012, 12:13 AM   #25
dantwomey is offline dantwomey  Canada
More soon but I believe c2cthomas posted the answer.
Dan
Old 26th December 2012, 12:40 AM   #26
AudioMaker.Tech
Um, actually, that schematic is correct.
Old 26th December 2012, 12:46 AM   #27
I think the problem lies with my version of 'grounding'. I'm waiting on a replacement VFet. As soon as I know for sure I'll post a detailed and well illustrated report.
Dan
Old 26th December 2012, 01:09 AM   #28
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
I went back and looked and said to myself that being the big dummy that I am I would need to wire it up and do a double check on it. But I have to agree with you Michael - upon a 2nd look it does look correct. OTOH - I am all to familiar with the term "smoke test".
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 26th December 2012, 01:14 AM   #29
I smoked a VFet so all potential answers will have to wait for a little while.
Thanks again for everyone's assistance and input.
Dan
Old 26th December 2012, 07:22 AM   #30
juanitox is offline juanitox  France
juanitox's Avatar
try it first with a 1ohm source resistor , it sounds near as good with a 100000uf bypass cap and it is "indestructible" mounted like that..
happy christmas to all ..
French is not a crime.
SIT Startup Problems - What did I miss?Hide this!Advertise here!
SIT-1 and SIT-2 owner manuals Nelson Pass Pass Labs 25 12th September 2012 07:16 PM
Gone for years....so what did I miss? KT Parts 7 27th August 2012 12:55 AM
NCD1 problems: No blue led blinking at startup Thzar Class D 51 13th December 2009 01:42 PM
Who Doesn't Miss Jocko. fdegrove Everything Else 7 24th December 2002 01:34 PM
Copyright ©1999-2017 diyAudio
