what obvious perceived sound quality segments found in Class A compared to AB? - Page 2 - diyAudio
Old 23rd December 2012, 02:00 PM   #11
dewardh is offline dewardh  United States
Originally Posted by Pano View Post
There are other advantages, of course. Such as the lack of crossover distortion . . .
That's the one. Its absense is also why "Class D sound" is often compared to "Class A sound". And it's the very essense of the "first watt" concept . . . that's where crossover distortion is worst, and most noticeable, in most amps.
Simple harmonic distortion hardly matters, we don't hear it at the (low) levels that can be accomplished in any reasonably competent amplifier. It's a useful test only because it's a proxy for IM (which is easier to hear and harder to measure). Keep the IM low and the crossover distortion lower and all is good . . . (and never dirve any amp to clipping . . .).
Old 23rd December 2012, 02:08 PM   #12
6L6 is offline 6L6  United States
6L6's Avatar
I'm not an audio reviewer so I might not be full of lovely prose and illuminating elocutions...
Simply put, the class-A amps that I have heard (mainly Pass designs) have a certain rightness about them - some have likened then to having all the advantages of a tube amp without the downsides of tubes, and also having the qualities of a good solid-state amp without their downsides.
You will like it, I'm sure!
One thing to remember, however, is that for some people and some systems 25W per channel might not be enough... so don't blame the amp in that case. (But most people are pleased as punch with their amps. Should you find it necessary, there are a couple ways to get lots more power in the Pass/Firstwatt series.)
Old 23rd December 2012, 02:11 PM   #13
With any amplifier worth using, speaker drives obvious perceptions.
Old 23rd December 2012, 02:16 PM   #14
analog_sa's Avatar
Absolutely. Or you can swap speaker and amplifier in the quote and it still makes perfect sense
Old 23rd December 2012, 02:24 PM   #15
6L6's Avatar
Extremely true.
Philosophically speaking, it's not a bad way to choose speakers that you really love and build a system around them.
Old 23rd December 2012, 03:08 PM   #16
Well designed AB is easy to bias crossover into linear region of output devices, extending range of greatest linearity. Within this region, crossover distortion is lower than non linearity in output devices across operating range. Further biasing into A range has rapidly diminishing returns of improved distortion v dissipation.
Single ended output performance is limited to biasing quiescent point to center of output device's most linear range.
All loudspeakers with efficiency suitable for low wattage amplifiers inherently distort at orders of magnitude greater than lowest distortion drivers.
So, no inherently different performance in signal output, lots more heat with class A.
Andrew
Old 23rd December 2012, 03:35 PM   #17
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
aha
say that to guys who made Altec 515
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd December 2012, 08:02 PM   #18
Bigun is offline Bigun  Canada
Bigun's Avatar
At the expense of heat, of course!
Class AB amps can theoretically be 78.5% efficient, but as they are often built with high maximum power output they are operated far below their maximum output power and require biassing to minimize cross-over distortion they tend more often than not, to achieve more like 50% to 60% efficiency.
A choke loaded single ended Class A amplifier can theoretically be 50% efficient. And since they are usually built for lower max power output they tend to make more use of their theoretical efficiency.
At some point I would guess that a low powered Class A amplifier is no worse for heat than a high powered Class AB amplifier ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 23rd December 2012, 08:14 PM   #19
6L6's Avatar
Yes, kinda... That would mostly be dependent on how high the AB amp is biased, and/or how hard you are running it.
It's not really apples to apples, but I know what you mean.
Old 23rd December 2012, 08:17 PM   #20
diyAudio Member RIP
A silly argument. Whilst AB efficiency varies so does its power draw.
Class A draws the same power regardless of level and it never gets
anywhere near like 50% efficiency for any real music programme.
Single ended class A can't get past 25% efficiency and in real life
with real music is horribly inefficient, especially if typical listening
levels are below clipping levels.
rgds, sreten.
sound Quality of OPA549 when compared with LM3886 rhythmsandy Chip Amps 24 23rd February 2013 09:11 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
soundstream reference class A 6.0 compared to McIntosh MCC404 in sound quality russdeanlee Car Audio 0 5th February 2012 10:33 PM
soundstream sa244 compared to original reference line in terms of sound quality russdeanlee Car Audio 1 27th December 2011 10:12 PM
Quality of filter caps in class A or AB designs. beppe61 Parts 7 9th February 2006 07:19 PM
Copyright 1999-2017 diyAudio
