Recompensating a Stasis 3 - diyAudio
Old 15th December 2012, 09:38 PM   #1
Default Recompensating a Stasis 3
I've rebuilt a defunct Stasis 3 amp with blown outputs on one channel. I replaced the outputs in both channels with MJ21195/MJ21196. I recapped and replaced the transistors on the input board. I used the same type of transistors except for the diff pair, for which I used ZTX696a. However, any attempt to replace the 2sa1112/2sc2592 pre-drivers with a variety of subs resulted in immediate oscillation.
A 10k square wave into 4 ohms showed significant ringing, but no overshoot. The ringing was much worse without a load. I replaced the 39pf base-collector mica's on the pre-drivers with 100pf with improvement. Then finally 200pf micas eliminated most of the ringing.
Am I going about this correctly?
I've attached pictures of the 100pf and 200pf scope outputs.
400A or Stasis 3? Mywing Pass Labs 6 4th November 2007 06:53 PM
Threshold Stasis 2. steenoe Pass Labs 52 29th August 2007 06:59 AM
Stasis One Meter bagigios Pass Labs 0 22nd December 2006 02:37 PM
STASIS 2 problem WolfgangL Pass Labs 27 27th September 2005 03:28 AM
stasis 2 and 3 schematics Nelson Pass Pass Labs 39 3rd February 2004 05:53 PM
Copyright 1999-2017 diyAudio
