F5 measurement/tuning
Old 24th December 2012, 02:39 AM   #21
doolav is offline doolav  United Kingdom
I never tried to adjust P3 pot (the pot to balance 2-nd and 3-rd harmonics) 'properly', i.e. with a spectrum analyser - just tried to get it to the middle position for now. Can this pot misbehave?
Old 24th December 2012, 02:51 AM   #22
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by doolav View Post
having got it from tech-diy, I had assumed so, never tested them.
i checked all the JFETs before they go out.
and i don't do F5 kits anymore -- althought i use between 4 and 8 of them at any given point of time.
Old 24th December 2012, 11:09 PM   #23
Jack, this has been ordered a while ago (a year or so if I remember correctly), it's just quite recently the amp came to life (as time permitted), and even more recently I managed to take these measurements.
Thanks for the kit and even more so for the PCBs - it's certainly not taken for granted.
Would you have any version of why I have such a difference between channels?
Thanks,
Alex.
Old 3rd January 2013, 01:01 PM   #24
Ashg is offline Ashg  United States
Did you test each component prior to using it? have you played about with topology? i dont know if the picture in post 11 is recent? a couple of comments on it. the transformer at the front seems to be missing the top cap fixings (can affect behaviour), bottom cap board looks way to close to the transformer can you raise it higher.
think about the magnetic fields going on inside the chassis and try to balance them out
it may be worth taking everything out the case and laying it spread out on the table to test, to rule out topology, if it behaves out of the case you may need to rethink the layout. maybe try mounting the transformers vertically one at the front and one at the back, un-stacking the cap boards and fixing them to the bottom of the case mount the rectifiers on the front and back panels, run the signal cables in the top of the cabinet and the power along the bottom.
Old 3rd January 2013, 03:05 PM   #25
Hi Ash,
I have tested the resistors (had to swap some), but did not test the j/mosfets (not sure how).
I also tested both PSUs before connecting to the boards - they are ~26.5V (or ~24.5V +/-0.5V when loaded). The PSUs are irrelevant in my issue, as I found swap them does not swap the channels behaviours, i.e. it's PCB-bound (having all the resistors checked and matched at ~1%, does it mean the transistors are misbehaving?)
Layout - yes, a lot of relocations were made here. I expected more influence from the transformers positioning, but there was not! Transformers on sides, stacked transformers, transformers apart, caps away from the transformers, one transformer/one cap bank, one transformer/two cap banks, main boards away from everything (20cm from transformers/caps) - tried all these permutation.
Surprisingly the boards were not influenced by the proximity to transformers in my small enclosure (it is 21cm(w) x 30cm(d) x 21cm(h)). Here is its latest state:
Old 3rd March 2013, 07:49 PM   #26
Just trying to get back on track with it. Started with resetting the bias yesterday. So far one channel (after about 1hr warm up) is perfectly steady at 858-862mV with offset at 2mV.
The other channel (with the high frequency loss) is jumping all around 750-930mV (changes within 1-2 seconds!), offset is not bad, but drifting -5+10mV (not as rapidly as the bias).
Any debug ideas - what voltages at what points to measure?
I suspect the input jfets - how to diagnose if they are bad? Don't have them spare, so would like to confirm if possible before reordering new.
F5 measurement/tuningHide this!Advertise here!
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 11:56 AM
1M-F5 - A 1 MHz F5 project triode_al Pass Labs 43 25th October 2012 08:28 AM
Guitar and Bass, tuning tuning tuning tinitus Instruments and Amps 54 18th May 2012 08:01 PM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 05:23 AM
Sub tuning fortyquid Subwoofers 3 29th September 2003 07:33 PM
