#51 |
We won't make the source code public.
But we can manage to support two versions I think. Patrick
xen-audio.com |
#52 |
Newbie
Thanks Patrick. Looking forward to the next (last?) installment on the preamp. This unit should perfectly fit the needs of my system.
Have a great holiday! |
#53 |
Knowing how you love SMDs, I was almost certain we'd see MELFs on the attenuator!
Merry Christmas Patrick and Xen gang!
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones |
#54 |
Actually none. See post#2.
Patrick
xen-audio.com |
#55 |
I know, I was surprised!
#56 |
Bravo Patrick.............best project in a while.
How about a conceptual schematic (block diagram/flow chart). Definitely a must build. Thanks and Merry Christmas................... ![]() Regards, Jam |
#57 |
Patrick
Is it possible to run two preamp boards in your case, as I am using J Rivers MC18 as my sole source and crossover (as i cant find a suitable balanced crossover to place after the preamp) outputting two signals, Hf,LF, over USB into a exaU2I Multichannel Asynchronous USB to I2S Interface, into two dacs, into two? preamps, feeding two of your FX5's. Or can anyone suggest a better way of going active balanced ? Tony |
#58 |
A friend is using F5XP & F5X for active crossover for his 2-way bookshelf.
He is going to use the F5XP to drive a purely passive filter network (LF & HF parallel). These networks are followed by JFET follower, which then drives the F5XP. I consider this a good solution indeed. Patrick
xen-audio.com |
#59 |
Thanks for the idea, LF & HF Parallel to obtain the balanced output? Any further details would be of great help.
Tony |
#60 |
No.
LF & HF in parallel so that you have one preamp driving two filters giving you 2 outputs. That is per channel, so 4 outputs altogether for 2 channels 2-way active filter. To use a passive filter followed by source followers, just treat them as single ended and duplicated 2x for balanced. Suggest you start a new thread and also let other people help you. Or you send me your X'ovr schematics by email and I'll have a look, when I have time .... Patrick
xen-audio.com |
| F5X -- the EUVL Approach | EUVL | Pass Labs | 812 | 14th May 2013 02:25 PM |
| 2 x EUVL F5X Designed Case | toufu | Swap Meet | 4 | 3rd October 2012 05:21 PM |
| F5X Case | Horio | Pass Labs | 34 | 14th August 2012 02:05 AM |
| F5X Transformers | mravinsky | Group Buys | 122 | 16th February 2012 06:18 PM |
| F5X Transformers | mravinsky | Group Buys | 1 | 10th January 2012 04:40 PM |
