Aleph J for Universal Mounting Spec
Old 9th June 2018, 03:36 PM   #741
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
use pair of IRFP150 , crank them to your liking
that's practically pair of IRFP240 in one case
so , no matching needed
for more info , look in (newer) Babelfish J thread
aha , yes - halve value of all 3W resistors , for that ........ 0R27 is OK
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 9th June 2018, 04:11 PM   #742
mattattnet is offline mattattnet  United States
Thanks, ZM
I will look at the thread, this sounds like a great option.
Old 9th June 2018, 08:19 PM   #743
chede is offline chede  Germany
... fascinated by amps
chede's Avatar
I can only second what Zen Mod said.
That case combined with the lower voltage should give you the option to run much higher bias current, which is a good recipe for best sound ...
In a case comparable to your 4U/400 I have run a single pair of IRFP140 at +/- 19V and 2.2 Amp bias current. Source resistors are 0.22 Ohms.
Best regards, Claas
Old 10th June 2018, 01:43 AM   #744
Thank you Claas,
I take it the .47R output resistors in parallel stay the same and dont change even with the source resistor change?
Matt
Old 10th June 2018, 08:24 AM   #745
Zen Mod's Avatar
nope
as I said - you need to change values of all
point me to your exact schematic , and I'll write them by nomenclature
Old 10th June 2018, 06:15 PM   #746
Hi ZM,
Sorry for my stupidity, when reading your Babelfish J thread, I see likely two .27R 3w resistors as output resistors if a single vertical pair of IRF120 with .27R source resistors are used.
Here is the schematic I will be following, it is the one from the most recent DIYstore Aleph J boards.
Old 10th June 2018, 06:23 PM   #747
Zen Mod's Avatar
whatever you do , R16,7,18,19,20,21,22,23 ...... are all of same value
of course that last group (sense group on output ) can be made of different number of resistors with different value (say , to have just 2pcs , not zillion ) , but group value must stay the same
practically - as many source resistors you have in output (counting up and down) , same number is in sense group
Old 10th June 2018, 06:35 PM   #748
chede's Avatar
Yes,
in my single output pair Aleph (like Aleph Mini), I have 0R22 for each source resistor and 0R11 as sense group total
Best regards, Claas
Old 10th June 2018, 07:47 PM   #749
thank you ZM, and Claas, my pea sized brain seems to be understanding now.
Matt
Aleph J for Universal Mounting SpecHide this!Advertise here!
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 11:51 AM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 10:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 06:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 12:49 PM
