Aleph J for Universal Mounting Spec
Old 20th October 2013, 03:36 PM   #641
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Are you guys talking about R5, the current setting resistor for the zener on the FE ccs, as seen in post 663?
...Shape the sound , Man!
Old 20th October 2013, 03:41 PM   #642
12B4A is offline 12B4A  United States
12B4A's Avatar
The CMF55 resistors you specced in the BOM are 1/2 watt rated @70șC and 1/4 watt @125șC.
Old 20th October 2013, 03:43 PM   #643
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
sole resistor needing more oomph here is LED voltage dropper
make it from two in series or parallel , whatever
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 20th October 2013, 08:02 PM   #644
WalterW is offline WalterW  Netherlands
Originally Posted by Zen Mod View Post
Q1b ?
you still can ....... but correct that logic
Oeps you're right it is about 4 volts higher
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
Old 13th December 2013, 08:50 PM   #645
delecoy is offline delecoy  United States
delecoy's Avatar
Default Aleph J V2 store boards
How are the new V2 store board different from the last version?
Old 13th December 2013, 10:20 PM   #646
6L6 is offline 6L6  United States
6L6's Avatar
Re-sized to fit the UMS, so the output PCBs and Front-End will fit in a 5U. (nice!)
Many more places for wire connections. (this is a big deal...)
Silkscreen updated so all PCB follow numbering of the F5Tv3 schematic in Nelson's original article.
Old 13th December 2013, 10:23 PM   #647
grimberg is offline grimberg  United States
grimberg's Avatar
Jim,
ALEPH J!!!
Old 13th December 2013, 10:31 PM   #648
6L6's Avatar
Lol... Sorry.
All the Aleph J boards in the store have been the "v2" - the v1 was the green prototype boards that were used as proof of concept. There were a few, very minor changes made from those to the production blue ones.
Old 13th December 2013, 11:58 PM   #649
delecoy's Avatar
Thank you much
Old 23rd December 2013, 12:01 AM   #650
roger57 is offline roger57  Canada
roger57's Avatar
Default Correct Wiring - RCA Inputs to PCB
Sorry to ask this question which may be redundant - but I've been unable to see a wiring diagram that clearly shows wiring an RCA input jack to the latest rev of PCB (Blue PCB)
I understand the shield around the cable gets tied to ground at one side only, then to a STAR point; the center conductor goes to the "+IN" point.
Where does the "-IN" get connected to?
Aleph J for Universal Mounting SpecHide this!Advertise here!
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 12:51 PM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 11:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 07:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 01:49 PM
