Aleph J for Universal Mounting Spec
Old 5th December 2012, 05:46 PM   #21
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
whatever you do - edit those default Eagle packages , to have bigger pads
especially for resistors , but for semis too
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th December 2012, 06:13 PM   #22
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by Zen Mod View Post
Whatever you do - edit those default Eagle packages , to have bigger pads.
Especially for resistors , but for semis too
That seems like good advice!
Old 5th December 2012, 08:22 PM   #23
dux is offline dux  Croatia
Didiet
am also for 'long board'
Old 6th December 2012, 02:13 AM   #24
didiet78 is offline didiet78  Indonesia
Agreed. So I need some dimensions :
1. Resistors (small one) :
- Spacing = 10mm ( need longer?)
- Pad Diameter = ? mm
- Drill Diameter = ? mm
2. Cap C2, C3 :
- Spacing = 5.08 mm ( need bigger?)
3. Big Resistor :
- Spacing = 17mm ( need longer?)
4. Wire Pad
5. C1 elco or Film ?
6. Add Pot to R7 or R8 ?
7. Semi To92 (I use BC), and SJ74
8. IRFP Semi :
9. For Led wich one do you prefer, 2 Led (one Led for Each Rail ) or 1 Led as on schematic?
For Reference i use this schematic, but I change ZTX to BC.
Old 6th December 2012, 03:22 AM   #25
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
Originally Posted by 6L6 View Post
The intent of this board is that it will become the one sold in the DIYaudio store -- Hence the UMS and a few other tweaks.
Finally, an Aleph in the store? Cool!
My one request is that pads are spaced such that all the resistors will fit without having to stand them up or contort the leads (unlike the other Aleph board...).
Old 6th December 2012, 03:35 AM   #26
6L6's Avatar
LOL!!! I'm working on that right now...
Old 6th December 2012, 03:39 AM   #27
6L6's Avatar
5. C1 film as you have drawn it in most recent revision. People will want to use film, and 1uf at these voltages is small.
6. R7 Yes. R8 ?If there is space for it...?
9. One LED each rail. Nelson said the LED as drawn in schematic was nothing more than panel lamp. With 2 they can be indicator for rails, or if people just want lamp, they can use one.
Pinout of BC transistors is CBE. Pinout of ZTX is EBC. How about leave silkscreen genderless, but mark the pinout and the channel of device. (see Q5 in photo) This is similar to current F5 F4 boards.
Also, measured from current F5 board - (And I can locate my fine rule, so I won't even guess the hole sizes)
Small resistor lead spacing 12.5mm (That will easily fit a Dale CMF60) and input resistors have 2nd set of 5mm holes for expensive Caddock or vishay square package (see photo)
Large resistor lead spacing 15mm with 2nd hole for 5mm bent knee lead square package (see photo)
Old 6th December 2012, 04:18 AM   #28
Still on progress change eagle lib :
1. Small R spacing 12mm, drill dia 1mm ?, add 5 mm spacing for R Input.
3. Big R spacing 15 mm are enough?, add 5mm R
7. Add Pinout, change silk
For drill dia : small component 1mm, Big R 1.5mm, wire 2mm ?
Didiet
Old 6th December 2012, 05:46 AM   #29
Blues is offline Blues  United States
Blues's Avatar
Default Trim pots on:
R7 -trims output DC offset to zero
R8 -sets front-end LTP total bias current
R24 -adjusts Aleph Current Source to taste
R27 -trims 0.6V reference across R16/R17 to set output stage bias current
From way back when, done in AutoCAD... The HotRod Aleph Circuit Board
Old 6th December 2012, 07:26 AM   #30
Some change :
- Add pot for R8
- Add Resistor 5mm spacing for input and big resistor
- Make pad and drill bigger.
- Remove C1 elco, Led
- Change silk for BJT
Didiet
Aleph J for Universal Mounting SpecHide this!Advertise here!
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 12:51 PM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 11:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 07:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 01:49 PM
Copyright ©1999-2017 diyAudio
