Aleph J for Universal Mounting Spec
Old 5th December 2012, 01:17 AM   #11
AudioSan is offline AudioSan  Norway
aha then we are on the same page
*banging my head* Cviller's F5X. there is no F5x boards from him i did not get that the first time
and yes. like the F5c boards. only with more space between the 2 inner fets.
Old 5th December 2012, 02:14 AM   #12
didiet78 is offline didiet78  Indonesia
Originally Posted by 6L6 View Post
Didiet - That looks very nice!
How much lead spacing is there for the 'small' resistors? It would be nice to fit a PRP or dale RN60, as those are about as big as most 'audiophile' resistors. Some people will want to use them.
Great to see the pair of J74 - could you put a pot at R7 as a variable resistor?
If possible, the 0v traces should be bigger, and another wire pad added near the input to connect signal ground, psu ground and speaker ground at one place. See the F4 or F5 pcb in the store for an example.
Thank you so very much for your efforts!
Lead spacing for small resistor 10mm. I add pot for R7 and wire pad.
For long board, i'll try to make one.
Didiet
Old 5th December 2012, 02:21 AM   #13
6L6 is online now 6L6  United States
6L6's Avatar
But still the spacing for the UMS...
Old 5th December 2012, 03:14 AM   #14
yes 6L6. say 120mm between the inner fets. thats fine for UMS and then 40mm to the outher fets
Old 5th December 2012, 05:42 AM   #15
Default Aleph J Long PCB F5C alike
Long board
Didiet
Old 5th December 2012, 05:56 AM   #16
didi. thats what im talking about
That is perfect spacing
Old 5th December 2012, 02:25 PM   #17
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
Originally Posted by didiet78 View Post
Long board
That looks like a nice package. Where do we sign up for the group buy?
Old 5th December 2012, 03:05 PM   #18
6L6's Avatar
The intent of this board is that it will become the one sold in the DIYaudio store -- Hence the UMS and a few other tweaks.
A question for those smarter than me - (of whom there are many!)
?Does the entire amp see ground through R2??? It looks that way on the schematic, and on this board...
Regardless, the trace between the GND pads and R2 need to be thicker.
And if you could entertain another request, I would love to see an LED on each rail, so you can see at a glance that the amp board is powered correctly.
Old 5th December 2012, 04:20 PM   #19
Add 3 LED, V- to GND, V+ to GND, V+ to V-. Add alt Cap for C1, 22mm spacing.
Which one do you Prefer, Long board or square board?
Didiet
Old 5th December 2012, 04:28 PM   #20
6L6's Avatar
Wow! That is looking great!
The long board is ideal for this amp.
Aleph J for Universal Mounting SpecHide this!Advertise here!
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 12:51 PM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 11:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 07:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 01:49 PM
Copyright ©1999-2017 diyAudio
