Aleph J for Universal Mounting Spec Aleph J for Universal Mounting Spec - Page 17 - diyAudio
Old 8th February 2013, 05:12 PM   #161
bnorrish is offline bnorrish  United States
bnorrish's Avatar
It looks like the board accommodates different pot pin layouts. 3 pins aligned or 3 pin triangle like the 3386k. I have used the 3296Ws - it seems like it would work with the flexible layout - here is the 2k part.
652-3296W-1-202LF
Old 8th February 2013, 05:29 PM   #162
henryve is offline henryve  South Africa
henryve's Avatar
Yes, I have specced the 3296W pots for the 25 turn variants.
Old 8th February 2013, 05:52 PM   #163
buzzforb is offline buzzforb  United States
buzzforb's Avatar
3299 are better pots, IMO.
...Shape the sound , Man!
Old 8th February 2013, 06:38 PM   #164
grimberg is offline grimberg  United States
grimberg's Avatar
Could you elaborate on what makes them better?
Old 8th February 2013, 06:43 PM   #165
henryve's Avatar
I have compared the 2, and the only specced difference I can see is that the 3299 is specced to handle up 125 degrees C while the 3296 is specced to 150 degrees C. But I will add it as another option on the list.
Old 8th February 2013, 07:03 PM   #166
henryve's Avatar
I also see that for the 3299 series they spec the Number Of Turns as Multi-Turn, while the 3296 is specced as 25. What does that actually mean?
3299 added as an option.
Old 8th February 2013, 07:43 PM   #167
buzzforb's Avatar
I believe the wiper on the 3299 is a little heaver, maybe a double. Just more duarble part. Difference in price is minimal, in the schem of things. Unimportant if you plan on replacing with fixed resistor.
Old 8th February 2013, 07:50 PM   #168
grimberg's Avatar
I agree that the price difference is irrelevant. We just need to make sure it fits since the 3299 is larger: 3/8" square vs. 1/4" square for the 3296.
Old 8th February 2013, 07:51 PM   #169
buzzforb's Avatar
didnt realize it was that tight. 3296 is fine.
Old 8th February 2013, 08:46 PM   #170
henryve's Avatar
Actually, I think both will be fine. I have scaled the PCB on my PC screen and I believe the 3299 will fit.
Aleph J for Universal Mounting SpecHide this!Advertise here!
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 11:51 AM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 10:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 06:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 12:49 PM
Copyright ©1999-2017 diyAudio
