Aleph J for Universal Mounting Spec - Page 66 - diyAudio
Old 22nd December 2013, 11:09 PM   #651
6L6 is offline 6L6  United States
6L6's Avatar
Input Ground.
Old 23rd December 2013, 01:11 AM   #652
roger57 is offline roger57  Canada
roger57's Avatar
Originally Posted by 6L6 View Post
Input Ground.
That picture leaves no doubt
Thanks!
Old 23rd December 2013, 01:38 AM   #653
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
For single end input, ground the in- either at the board ( see the 6L6 build thread) or at the XLR plug itself.
W4S STP-SE - DIY Aleph J - Zu Audio Druid V + Undertone
(Analog) VPI Scout Sig - K&K Audio Maxxed Phono (Digital) microRendu - Bryston BDA-3
Old 23rd December 2013, 01:45 AM   #654
roger57's Avatar
Thanks for the info.
Old 23rd December 2013, 12:00 PM   #655
Techie Wanabe
Bones13's Avatar
Heh, I guess I put the iPad down while I was reading/answering the question, Jim's pictures were not up when I started the anemic answer I gave. I am mounting both RCA and balanced XLR jacks on my current build. I'm putting a switch near each pair of inputs to short the in- to ground between and to the side of the jacks. I intend to turn the switch so that when you flip the switch, it will point at the correct jack.
Old 23rd December 2013, 02:05 PM   #656
roger57's Avatar
That's an interesting and good idea.
I'm developing a PIC/uController PCB for mine that will control power-on surge, mute signals & temperature sensing. At the minimum the temperature sensing will output a signal to drive an LED for "Thermal" or Overtemperature" and could optionally shut power at relay. It will also control any shutdown surge (i.e., discharging power caps)
Optionally, fan control - don't need to use it if you don't want but will have the control signal for variable speed according to sensed heatsink temperature. That would be for those of you that want more bias with not quite enough heatsink
It will be small enough fit easily in the chassis and will not have anything in the signal path not cause any spurious noise.
Timeframe? I'd like to be done soon but I need to prototype on my bench build AlephJ before issuing any schematics (Just ordered the amp PCB's) and will put all the particulars here. I can develop in parallel in any case. If there's interest from users about getting a board, I'll have to understand how that works from DIYA or another user that's done this before about a "group buy".
I may ask some questions about the build as I go along but I see many of you (notably 6L6) have done a great job to document and provide ideas.
Gary
Old 23rd December 2013, 03:04 PM   #657
6L6's Avatar
Regarding circuit boards, what's normally done is you buy a small run, say 10 or 20, and sell them on group buy or similar. You have the chance to recoup the costs and make a few bucks for the next one.
Old 23rd December 2013, 04:20 PM   #658
roger57's Avatar
OK, thanks. When the development gets to that point, perhaps I can PM you fro a discussion on how to go from there.
If anyone has anything on their wish list for this project, please post it and I'll see how it can be fit in. I think the idea for XLR selection by Bones13 is a good one. Will figure out if and how this could be done through the controller circuit. Likely a soft-switch on the front. As many don't want or plan to use XLR, it might be still nice to have the inputs and have the option one day to use it.
Old 23rd December 2013, 06:33 PM   #659
Techie Wanabe
Bones13's Avatar
I am using this board for my switch circuit
The ε24 Power Switch Driver Circuit
It has capability for 2 thermistor cut offs, and can change the switch LED color with temp controlled shutdown.
I also am using a DIYAudio store soft start circuit after the relay controlled by the switch circuit.
Old 23rd December 2013, 06:45 PM   #660
roger57's Avatar
Nice! One doesn't have to reinvent the wheel, so to speak.
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 11:51 AM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 10:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 06:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 12:49 PM
Copyright 1999-2017 diyAudio
