Aleph J for Universal Mounting Spec - Page 60 - diyAudio
Old 11th October 2013, 10:51 AM   #591
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Signal Jenny proggie from net , to give you a sine , cheap DVM to measure/establish some voltage at output ( say 10V) , dummy load ( anything between 4 and 16R) and to measure voltage across lower Rs for open/closed R0
voltage measurement only need to be relative , not absolute , so DVM doesn't need to be of lab quality
so , you have it all
aha - Signal Jenny : https://dl.dropboxusercontent.com/u/...8/SigJenny.zip
R0 is R24 here :
(you need to measure voltage across R18 or R19)
edit : my Paesano Logic is telling me that you're at 50% AC gain when AC voltages are same across ,say, R19 and R17 ......... but I'm never sure how's my brain working ...... biz as usual - Mighty ZM in constant state of Public Disgrace
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th October 2013, 11:31 AM   #592
Marra is offline Marra  United Kingdom
Thanks again you are a mine of information.
Old 13th October 2013, 02:14 PM   #593
Does anyone know if PD's aleph J boards will fit the UMS?
I have some which I started to populate, they need a case now though and the diya ones look to fit the bill. I know I could just fly lead them off the board, but if they boards fit it's perfect.
Old 13th October 2013, 02:27 PM   #594
6L6 is offline 6L6  United States
6L6's Avatar
The Peter Daniel boards don't even come close to fitting the UMS.
However, you could drill and tap a few holes and mount them, with or without the fly leads. The spacing on the UMS is pretty large, so you wouldn't interrupt any of the existing holes, and the UMS would be able to be used for future projects.
Old 13th October 2013, 05:42 PM   #595
Ok, thanks. Will put some more thought into it. It may be worth getting the diya boards just for the simplicity. I don't have many components fitted to the pd board, so the replacement part cost would be worth it compared to the hassle of pulling the tap set out.
Old 13th October 2013, 05:48 PM   #596
6L6's Avatar
That's quite logical.
Old 13th October 2013, 07:38 PM   #597
That's what I did unstuffed the PD boards and used the shop pcb's.
Old 14th October 2013, 08:24 PM   #598
WalterW is offline WalterW  Netherlands
Finished my Aleph J...
I built it in my F5 chassis which wasn't a big trouble because of the UMS specification, and the 24 volt needed for almost all Firstwatt amps.
For the F5, I used a 3 U hifi2000 chassis which isn't big enough for the Aleph J.
I can bias the Aleph cold at 400 mV over the 0.47 Ohm source resistors which results in 55C heatsinks with the lid off !
The amp seems very robust, bias lowers from 400 mV to 380 mV when warming up. So it bias itself lower when heating up!! That's not the way a F5T reacts
Offset is very stable within a few millivolts. A nice stable and complete Amp. I left out the current limiting.
I have been listening and comparing the Aleph J against the F5Tv3 for a week.
Aleph J wins in the highs and mid highs... what a detail, best I ever heard. Hi hats, cymbals, electronic music..WOW
But the F5Tv3 wins with bigger soundstage...the Aleph J seems more compact.
There is no real winner, both amps sound different, even my wife noticed but they are both great !
Next is to build the Aleph in his own chassis, I'm thinking of a easy, compact, nice computer case with ( very silent) forced air cooling
Like the cases of Streacom, Fractal Design and Lian Li ...
And of course, as always...here are the pictures...
Thanks of course to Mr. Pass and Jim (6L6) for his great Aleph J kit and building guides!
Last picture is the Pass Trio...
Walter
File Type: jpg 5- complete Aleph J missing one jumper.jpg (399.5 KB, 186 views)
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6
Old 14th October 2013, 08:31 PM   #599
12B4A is offline 12B4A  United States
12B4A's Avatar
Very nice and clean layout work!
Old 14th October 2013, 08:37 PM   #600
6L6's Avatar
Fantastic! It looks wonderful!
I'm very glad to hear that everything is working well!
So, now that your Aleph is complete... what's next??
Cheers!!
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 11:51 AM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 10:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 06:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 12:49 PM
Copyright 1999-2017 diyAudio
