Old 8th February 2013, 08:56 PM   #171
henryve is offline henryve  South Africa
henryve's Avatar
Actually, I am more concerned about C2 and C3. I would seem from my measurements on screen that the 50V Nichicon Muse (KZ) and Elna Silmic II options with 7.5mm lead space will not fit. The Nichicon Fine Gold (FG) option will fit though. I do see however that there is a 35V Elna Silmic II that will fit, but that specific part is not yet available from Mouser. There is unfortunately not a Nichicon Muse in 35V available. So I leave it to the builders to make up their own minds as I believe that the Nichicon Fine Gold is a good enough cap for those positions.
Old 9th February 2013, 12:45 AM   #172
C2 and C3 5mm spacing. Maybe we can add later in final rev PCB so it can accomodate 5 and 7.5 mm caps.
Pots 2.54mm spacing
Didiet
Old 9th February 2013, 05:23 AM   #173
henryve's Avatar
Didiet
Is it possible that I can get a PDF of the top layer only to print. It will make it easier for me to check spacing without having to measure with a ruler on the PC screen?
Henry
Old 9th February 2013, 05:32 AM   #174
I hope this would help
Didiet
Old 9th February 2013, 05:53 AM   #175
henryve's Avatar
Thanks, this is perfect.
Old 9th February 2013, 06:01 AM   #176
henryve's Avatar
Good, now that I have a nice printed copy of the top layout I can see that the 3296Y and 3299Y models of the trimpots will also fit, and is actually a better choice than the W variants since the mounting to the board will be sturdier because of the staggered layout of the pins. I will add the Y variants to the list of pots and consider the selection of pots on the BOM now more than adequate unless somebody has something else worthwhile to add.
Old 9th February 2013, 06:21 AM   #177
henryve's Avatar
Updated BOM.
BTW, for some odd reason MS Words conversion to PDF is not working too well as you can see that some table lines are missing when viewing on screen. It does show on the printed version but somewhat thinner than the other. Odd.
Old 9th February 2013, 10:11 AM   #178
bnorrish's Avatar
Looks good. CutePDF is a good free PDF creator.
Old 10th February 2013, 04:02 PM   #179
henryve's Avatar
A correction and some more updates.
Old 10th February 2013, 04:08 PM   #180
6L6 is offline 6L6  United States
6L6's Avatar
Great work! looking good!
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 11:51 AM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 10:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 06:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 12:49 PM
Copyright ©1999-2013 diyAudio
