Aleph J for Universal Mounting Spec - Page 16 - diyAudio
Old 8th February 2013, 09:58 AM   #151
C6 : 100nF - 1uF or just leave empty
R28,29 : depend on LED, 3-5Kohm
R30 : wire jumper, or 1 - 100ohm
Didiet
Old 8th February 2013, 10:14 AM   #152
henryve is offline henryve  South Africa
henryve's Avatar
Didiet
Am I correct in assuming that LED1 has been dropped from this PCB?
Old 8th February 2013, 10:20 AM   #153
Yep and change to Led2 and Led3. Just to show all voltage rail are ok (request from 6L6)
And C6, C7, R30, J1, J2 are sugested by ZenMod
Didiet
Old 8th February 2013, 10:48 AM   #154
henryve's Avatar
I am making an assumption that C2 and C3 can be 16V electrolytics. Obviously something like Elna Silmic II or Nichicon FG or KZ.
Old 8th February 2013, 11:13 AM   #155
henryve's Avatar
For C4; is 35V or 50V OK? I was thinking 50V?
Old 8th February 2013, 11:18 AM   #156
For C2 and C3 min 35V or even better 50V, for C4 25V would be fine.
Didiet
Old 8th February 2013, 12:42 PM   #157
henryve's Avatar
Updated BOM. Please give some feedback. 6L6, Didiet; please check if C2 and C3 can accommodate capacitors with a lead spacing of 7.5mm.
Old 8th February 2013, 02:54 PM   #158
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by henryve View Post
I see on the original schematic from Nelson that R7 is 1K. So it just makes sense for a 2K multi-turn pot.
Yes, a 2k is perfect there.
The 500ohm is a reference to the Aleph Jango, and not appropriate to the Aleph J -- my mistake.
Good catch, BTW!!
I usually prefer the 25 turn ones, not the flat ones which only provides 1 turn resolution.
That's a good thing to make note of on the BOM - please illustrate why you are making the choices and also what other type of peices can work. This way people can learn something about parts selection, and also have alternatives in mind if their suppliers don't have the 'right' part.
I will be happy to send you actual measurements from the PCB once I have them in hand, Didiet can tell you the dimensions in the meantime.
Old 8th February 2013, 03:44 PM   #159
I think the best way is not to replace a resistor by a pot. if you use a resistor in series to the pot resistance can never below the value of the resistor and the pot gets easier to adjust. ...
Old 8th February 2013, 04:21 PM   #160
henryve's Avatar
BOM updated with more trimpot info.
I would like to have some input from experience DIYers out there. From an image of the PCB I can see that only the 3386K model single turn pot will match the pin arrangement. However, I see that neither Mouser nor Digi-Key have stock of that specific model. Advice will be valued. I have also attached the Bourns 3386 data sheet, so if one of you out there can have a look at that it would be very helpful.
I also tried the Vishay model 36P as specified on the PCB, and did not have luck either although it does seem that RS stock some values for the Vishay range.
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 11:51 AM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 10:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 06:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 12:49 PM
Copyright 1999-2017 diyAudio
