Aleph J for Universal Mounting Spec - Page 15 - diyAudio
Old 7th February 2013, 08:43 PM   #141
bnorrish's Avatar
This may help. A BOM I did based on the original Aleph J schematic. May just need to mod for the PCB parts and review my choices.
Old 7th February 2013, 08:51 PM   #142
henryve is offline henryve  South Africa
henryve's Avatar
Thanks bnorrish. I will use some of your parts and ideas and bring some new ones to the table. Especially thinking of adding the Panasonic 3W resistors also as an option.
Old 8th February 2013, 12:04 AM   #143
skunark is offline skunark  United States
Sign me up for a pair as well
Old 8th February 2013, 12:51 AM   #144
bnorrish's Avatar
Post #68 - was that the final layout, schematic?
-R7, R8 are 500 ohm pots?
- What about R27 - what value pot?
- J1 and J2 are resistors - what values?
Old 8th February 2013, 12:52 AM   #145
bnorrish's Avatar
Go nuts Panasonic blue vs Vishay brown
Old 8th February 2013, 01:40 AM   #146
- For R7 pots min 1K, i prefer 2K
- R8 you can use 500 ohm pots, but value for R6 min 560 ohm
- J1 and J2 are gate stoper. You can jumpered or use resistors, wit value from 0 to 220 ohm
CMIIW
Didiet
Old 8th February 2013, 01:44 AM   #147
buzzforb's Avatar
IT is better to have more headroom wit hpot. Ideally, you hav a fixed value resistor and then another por in series.. Once you get it biased, you can replace with permanent resistor of matching value.
...Shape the sound , Man!
Old 8th February 2013, 06:54 AM   #148
henryve's Avatar
6L6
I see on the original schematic from Nelson that R7 is 1K. So it just makes sense for a 2K multi-turn pot. I usually prefer the 25 turn ones, not the flat ones which only provides 1 turn resolution.
Feedback welcome as usual.
Old 8th February 2013, 09:34 AM   #149
Default Aleph J Single Layer
This what it like in single layer. Just add Jfet and N-Mosfet and Big Heatsink.
Didiet
Old 8th February 2013, 10:47 AM   #150
henryve's Avatar
Right, attached is my first draft of the BOM. I still need some input with regards to the values of the bypas capacitor C6 as well as the values of resistors R28, R29 and R30.
Also I have seen no suggestions for a value of the R27 trimpot.
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 12:51 PM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 11:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 07:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 01:49 PM
Copyright 1999-2017 diyAudio
