Aleph J for Universal Mounting Spec
Thank you Henry and Luvdunhill. Didnt see the schematic. In that case, I would go for FM, simpli because of specs. I dont think you will be heaing that cap and so you want best possible parameters. The FM beats other suggestions from a numbers standpoint. C5 is where I would use Elna RFS, as well as ACS.
Personally I used FC and FM for my KSA50 clone, but I am not so familiar with the Aleph J so I erred on the side of reputation as you may say. But I will add FMs where possible also. I will see if I can do a proper schematic also based on that used by Didiet for the PCB layout. As I said, this is my first contribution and learned much. I hope in future to do some layouts also.
6L6
Moderator
Joined 2010
Gentlemen, the boards --
Prototype testers, I will hopefully have the in the mail tomorrow. :)
