F5 - is normal ICs twist out the Hum?
Old 29th November 2012, 11:47 AM   #11
Blink_PT is offline Blink_PT  Portugal
Blink_PT's Avatar
I've done everything, and I'm about to give up.
This hum is not a problem ground, turned off the ground while doing the experiments, the ground on or off is equal.
The problem is mass, with everything turned off and only the F5 on the speakers as makes no hum, just connect the ICs that starts right tinnitus.
I used many ICs, directional unshielded at the destination, the unshielded source, etc, etc.. and nothing, always that little hum.
I am forced to think that the problem lies in the components, or 400VA toroidal Sedlbauer of Conrad, or PCBs in the channels or the PSU pcb (Jim Audio).
The AC input wires are shielded by the toroidal.
I wonder why he only hum when I turn the ICs with the same pre Rotel off
I have exhausted my wisdom.
Old 29th November 2012, 11:59 AM   #12
flatheadmurre is offline flatheadmurre  Sweden
If you´re sure the grounding is not the problem (i can see that left side signal ground goes through right side amp to ground).
Try shorting the signal in right at the cards (solder a wire across in and ground).
Old 29th November 2012, 03:34 PM   #13
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
there is no other way than to post good pics of PSU board , both sides
now I remember that we already solved some problem with similar pcb , in some thread
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 29th November 2012, 03:41 PM   #14
From Blink's description it sounds like the ground loop is in the interconnects link to the amplifier/receiver.
If the Source has a common ground point for the two output phonos and the receiver also has a common link between the two input phonos, then there MUST BE a ground loop.
That loop requires that the route have a current reducing resistance inserted to minimise the voltage appearing along the interconnect return wires.
regards Andrew T.
Old 29th November 2012, 03:46 PM   #15
Short the inputs right at the boards.
No hum = ground issue between amp and pre or hum pickup in signal cable.
Hum = grounding or PSU issues in amp.
That it should be component issues in both channel is not likely.
Old 29th November 2012, 06:55 PM   #16
Blink_PT's Avatar
That's exactly what happens.
With F5 only on the speakers as no hum (without interconects connected).
I have been to confirm and all the RCAs Rotel have common mass.
When I turn to only one pre interconnect (Rotel RA-1520) there is no hum, turning on the 2nd there appears hum.
If you turn off one interconnect the hum disappears. I listen to music in stereo, of course.
I'll put the pics of the PSU.
When solving this hum, I'll open a bottle of champagne.
Did the voltage on the output DC to AC multimeter scale and each channel has +- 0.012V, I think the PSU is okay...
Old 29th November 2012, 07:04 PM   #17
Zen Mod's Avatar
did you tried that fat wire bridge ?
Old 29th November 2012, 07:11 PM   #18
Blink_PT's Avatar
Yes, soldered a fat wire between the GND left channel and the GND right, has the same hum, it seems that even a little longer.
I had already made ​​this connection before, now everything is standard.
Old 30th November 2012, 12:32 AM   #19
kasey197 is offline kasey197
The Dastardly Dad of Three
At risk of stating the obvious, given the issue is with this particular preamp, why dont you just disable the input ground on one of the interconnects either in the preamp OR in the f5 amp.
Example:
left channel : Hot and Ground,
right channel: Hot only no ground.
Not ideal but if it works ....
Old 30th November 2012, 03:38 AM   #20
omishra is offline omishra  India
Okay, I faced similar situation in another amp, not F5. It was connecting both input grounds used to start hum while disconnecting either one input ground - no hum. Yes I agree its ground loop in input return path.
The similarity here is, PS used here is too having single floating ground. Simple solution which worked for me was - separate both input RCA ground from each other and chassis. Run them to the amp PCB input ground pad. Connect PS ground separately to each amp board and speaker output. This you have done correctly. Only problem I see input ground need to run separately till amp board.
Just for curiosity , does your preamp has zero resistance between grounds of both RCA?
F5 - is normal ICs twist out the Hum?Hide this!Advertise here!
F5 hum preiter Pass Labs 10 3rd June 2012 02:10 PM
Unable to fix hum on my F5 anilva Pass Labs 43 24th May 2011 08:06 PM
Heater circuit - to twist or not to twist Rob11966 Tubes / Valves 19 20th July 2008 03:08 AM
transformer hum....is it normal??? eddog Chip Amps 4 4th May 2006 08:36 PM
