Just a question: How much ripple voltage is ok for an aleph? I'm getting 75mV ripple pp at the output. The bias current is 4A Is this normal for that circuit and a power supply ripple of 350mV pp?? Christian |
#2 |
Pumuckel
Recently, the topic of power supplies for the Alephs has become interesting again. See here and in the Aleph-X wiki for more information. 350mA from the power supply seems high to me and I would look to quiet that before looking further up the amp. I would ask some of the other members in the thread above their opinion since they may know more about the pre-X Aleph. |
#3 |
The one and only
With that much ripple on the supply, you should be seeing
maybe 300 micro-volts of ripple, or about 1/1000 of the supply ripple, or less. |
#4 | |
Your descripion sounds like you are collecting "hum" somewhere not ripple! Look if this is 50 or 100Hz! -> 100Hz is maybe some PSU induced hum. -> 50Hz is maybe grounding problem. Put away all input cables make a shortcut on all 3 input pins and look if the hum changes. Uli
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#5 |
Thanks for the replies.
I already thought that it's much too much. It's 100Hz ripple. What coud be the reason for that. I matched the input fet's not only by their gate/source voltage but by their characteristics. Any Ideas?? Christian |
#6 |
HI,
Here are a few measurements of the ripple I took right now. the funny thing is that the left and right channel behave different. What in the aleph circuit is responsible for the PSRR? How does the bias current of the first stage affect PSRR? Any ideas?? I'm sitting in the lab right now, so I can try things out and give feedback. Christian |
#7 |
other channel
#8 |
... I forgot to say that I'm using a LC Filter now. That's the reason why the ripple is much lower, but the ratio of supply ripple vs output ripple didn't change much.
Christian |
#9 |
The one and only
What's the noise figure on the good channel?
#10 |
I wouldn't say that there's a good channel, because the ripple of the output is 1/10 of the supply ripple.
The traces are averaged, to only see the 100Hz ripple. noise is about 15mVPP |
| Huge AC ripple voltage - Help Please! | johnmax | Power Supplies | 5 | 2nd February 2008 10:54 AM |
| How to determine ripple voltage? | beerman | Power Supplies | 4 | 21st February 2007 07:27 PM |
| Optimal ripple voltage on b+ supply | nhuwar | Tubes / Valves | 14 | 1st February 2007 05:01 PM |
| What is a reasonable amount ripple voltage for a 300B? | sgerus | Tubes / Valves | 3 | 30th October 2006 09:44 PM |
| How low should PSU ripple voltage be in a preamp? | DrewP | Tubes / Valves | 5 | 6th February 2003 07:43 PM |
| Page generated in 0.11198 seconds (72.27% PHP - 27.73% MySQL) with 11 queries |
