could the  F5C or F5T be run at 40v rails?
Old 26th November 2012, 02:39 AM   #1
JZatopa is offline JZatopa  United States
Default could the F5C or F5T be run at 40v rails?
I'm curious if the F5C or F5T could be run at 40V rails? Is that still to high for the cascoded frontend?
There is no higher religion than truth
Old 26th November 2012, 04:59 AM   #2
AudioSan is offline AudioSan  Norway
hello. with cascoded FR. it can be run at +/-40V rails.
but you need at least 3 pairs of outputs to get anything out of it.
Old 26th November 2012, 05:33 AM   #3
dazed2 is offline dazed2  Canada
what do you mean by that?
Old 26th November 2012, 05:54 AM   #4
becouse out over that, it can be hard for only one pair of input J-fets.
well. it can handle 4 pairs. 3pairs may be the better chose.
and with +/-40V rails. you want to get someting out of it. with somewath high bias. to get full out of +/-40V you need 2.4A bias
that is at 8ohms.
Old 26th November 2012, 08:27 AM   #5
Could it be done with as little as 2 pairs?
Old 26th November 2012, 08:43 AM   #6
yes. for v2 turbo.
Old 27th November 2012, 03:14 AM   #7
Bksabath is offline Bksabath  United Kingdom
Banned
Cascode vill take 40 V rails
But to keep thermal down (max 50 w disipation for each mosfet with proper heath sinks)
you wuld have to bias at 1 A for each mosfet with a bit of safety margin
So you run out of class A at about 8 V (but duble cek my maths) which ain't bad depending on speakers and listening abits.
To find out how much power you need cek this out
http://www.diyaudio.com/forums/multi...kers-need.html
Old 27th November 2012, 03:54 AM   #8
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
With adequate sinking, you could consider 1 pair, but you wouldn't want to
be abusing it.
Old 29th November 2012, 04:44 AM   #9
Thanks for the help guys, unfortunately I had to pass on the transformer I was going to use. I guess my F5T is going to have to wait.
could the  F5C or F5T be run at 40v rails?Hide this!Advertise here!
what class-D amps can run off of +/-90VDC rails? CharlieLaub Class D 16 27th October 2013 06:55 PM
LM4780 on 40V rails zdr Chip Amps 25 29th April 2008 07:35 AM
Chipamp request for Bi-Amp with SS amp, 40+40v supply rails -_nando-_ Chip Amps 7 16th June 2007 07:49 PM
LM4780 4ohm @ +/-40V rails alexcd Chip Amps 14 13th December 2006 05:27 PM
Will RevA run with 24volt rails? Wynand Chip Amps 13 22nd August 2006 07:06 PM
