#31 |
I have nothing but good purchases from online components.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#32 |
This should be very disturbing.
#33 |
#34 |
#35 | |
is choosing a less facetious title...
they periodically make statements about tracking/reporting fake parts on their site Last edited by qusp; 28th November 2012 at 10:47 PM. |
#36 |
Well, I don't think we're done checking devices yet.
A diode connected to the right pins could pass the test I just described. BTW, the circuit I described can be used for simple Vgs matching too. On MOSFETs also. Reverse everything for P ch devices. You can play with the voltages and the resistor to get any current you want. I don't think I wanna screw with, or describe to anyone, how to check d-s breakdown or anything(1200V ). But it is somewhat of a unique parameter not expected to be found in to many other devices. Rdson is pretty easy and although they use 12A you will likely, as in MOSFETs do, get the same results at much lower currents. You might get about the same numbers with an IRFP240. But, if you did the first test you would have thrown it away already after finding out how much voltage g-s it takes to turn it on(4V).Gotta think about it some more???
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#37 |
I guess you have to stock up on the parts as soon as Nelson says he's using them in a design and before they're discontinued. A lot of diy guys don't want to spend the money at the time and then get bruned looking for the parts afterward.
I'd be curious to know if Nelson has gotten burned? Would be funny if he used some counterfeit parts and the amp had a sound to die for, with no way of identifying the original parts. |
#38 |
yes well we all know that parts can sound better and offer a nice soft clipping when pushed hard, sometimes above their stated max (eg 2sk170 etc) what about when they are literally in their death throws because they are not the part you thought they were?
#39 |
certainly not possible , from many reasons
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#40 |
Those of you who experienced first hand this phenomenon of fake [buzzforb], please define it clearly. Preferably, please give a specific example which stood out. A production run ususally give a distribution of performance. Is the population of devices which happened to be on the fringes of a potential broad distribution the alleged fakes?
| FS: SemiSouth SJEP120R100 | ultrafi | Swap Meet | 17 | 29th November 2012 03:55 AM |
| SJEP120R100 Question | ultrafi | Pass Labs | 7 | 14th August 2012 06:15 AM |
| Law faking issue | oshifis | Parts | 2 | 6th April 2008 08:57 PM |
| Un-Faking a log pot | pixpop | Parts | 2 | 31st May 2006 03:57 PM |
| law faking pot Q | pjanda1 | Chip Amps | 6 | 28th March 2005 05:06 PM |
