Semisouth remaining stock
Old 18th January 2013, 11:51 PM   #11
rolandong is offline rolandong  Philippines
long live Nelson Pass... long live diy...
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo...
Old 19th January 2013, 12:08 AM   #12
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Blue Car!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th January 2013, 07:39 PM   #13
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
OK, so I set up a circuit to quick test one of the E120R10X that SemiSouthFan
sent me vs the R100 parts.
The stage was single-ended Common Source with no feedback driving 8 ohms.
The bias was a fixed 1.8 amps DC, and the Vgs was set for 20V Drain voltage.
The signal source was 600 ohms.
The Vgs of the R100 part was about 1.3V and the R10X was about 1.8V
Both exhibited nearly the same gain figures (~32 db) and bandwidth (see
resp curve below) and similar but not identical distortion numbers. (see
distortion curve below). Under these conditions, similar to the F6, the R10X
has generally lower distortion.
Two items of difference:
In the R10X I noted a higher Gate leakage figure of about 45 uA. Not a big
item, but something to allow for.
I also noted more drift in the R10X bias figure vs temperature, in fact I ended
up putting it in a simple control loop to stabilize it when running these curves.
In the F6, likely we would have DC degenerate or otherwise control the bias
current of the bottom device, which is of course not a big problem.
Old 21st January 2013, 04:13 AM   #14
Semisouthfan is offline Semisouthfan  United States
Thank you Nelson for taking a look at these parts. These parts are nominally identical to the R100 (same production line and design). They are R100 chips that sorted for threshold voltage about a quarter to a half volt higher than the R100 spec would allow. The SemiSouth engineering department had them packaged in TO247 to see what could be done with higher threshold parts in addition to the chips off these wafers that met the original SJEP120R100 spec.
Old 26th April 2015, 06:19 PM   #15
stefan5000 is offline stefan5000  United Kingdom
i have cooked one of my semisouth e120R100!Has anyone got one for sale???pls???
If' cutting corners is such a bad thing to do,people would have never invented the wheel!!!
Old 27th April 2015, 05:36 PM   #16
The one and only
Did you ask SemiSouthfan?
Old 27th April 2015, 05:39 PM   #17
I have just sent him Pm.
Semisouth remaining stockHide this!Advertise here!
"The Wire" Remaining Headphone Amp Boards and Kits opc Headphone Systems 204 15th December 2013 07:21 PM
Aleph 2 Built But Some Questions Remaining hifileslie Pass Labs 3 4th August 2009 06:30 PM
WTB: Stock or near stock ART DI/O buzzinghive Swap Meet 0 16th March 2007 09:06 AM
How to evaluate the laser pick-up remaining life beauty_divine Digital Source 3 11th November 2006 12:20 PM
