A little help needed, PLH no Bias !
Old 30th October 2012, 02:32 PM   #11
gbullimore is offline gbullimore  United Kingdom
Old 30th October 2012, 03:54 PM   #12
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
increase R3 to 510R
be back then
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 31st October 2012, 07:20 AM   #13
not sure it it's relevant, but i just checked and found i'm using IRFP240 from IR,
could this explain the difference,
when i get back from work i'll try increasing R3, but with these changes will i upset NP's delicate balance in the design?
Old 31st October 2012, 10:08 AM   #14
Zen Mod's Avatar
no ,irrelevant
no
Old 31st October 2012, 12:50 PM   #15
thanks again for the feedback,
tried R3=510R and still no luck,
with V+ at 40v, i can get the Bias to 0.89v.
but i checked again the wall voltage, and when running from the wall the V+ is 38.5
in this condition i can only get 0.68v Bias.
should i change R3 to 730R (the original 390 + 220R) or more like 780R (390+390R),
or altogether more brave at 1k,
or should i be looking at reducing R6 below 110R ?
starting to worry a little at drifting so far from stock values.
would a change in brand / type of IRF610 be better?
although it's be nice to get it up and running quickly without having to order more FET's.
by the way i have not yet changed R7, will this affect the bias much?
i'm seeing ~25v at the output cap,
but i see almost equal bias on all 4 devices
Old 31st October 2012, 01:28 PM   #16
Update,
I realized i'd been stupid by leaving R7,
I changed it out to 10k, now i can adjust to 23v at the output cap, but now the bias maxes out at 0.97v,
I guess if i change R7 to 47k i might be there, i might even need to undo the R3 or even R6 change.
Old 31st October 2012, 02:24 PM   #17
Zen Mod's Avatar
feel free to experiment
A little help needed, PLH no Bias !Hide this!Advertise here!
ADCOM GFA5500 bias voltage needed dballes15 Solid State 9 31st October 2012 02:44 PM
Help needed with bias circuit Rob11966 Tubes / Valves 18 1st March 2009 04:07 PM
Yamaha A-400 schematics/bias needed hiwiho Solid State 12 31st October 2005 02:38 PM
Tech help needed Threshold S/300 MkII optical bias georgehifi Pass Labs 4 18th January 2005 07:49 PM
Tech help needed Threshold S/300 MkII optical bias georgehifi Solid State 15 17th January 2005 02:30 AM
Copyright ©1999-2017 diyAudio
