paralleling mosfets in BLS
Old 7th February 2002, 05:31 PM   #11
ftorres is offline ftorres
ftorres's Avatar
I've tried a quick simulation (see attached image). It gives good results but no sound .
Well, regarding the gate voltage for the cascode mosfets, a rough approximation gives :
Starting from the input mosfet : gate @ 0V
Allow 10-15V more on its drain. Add 4.5V for the Vgs of the second mosfet. You get about 20V at the gate. Be sure that Ibias x Rload voltage drop let sufficient room for the second mosfet to behave correctly (10-20V more positive than the gate). That's only a quick way to go, but seems to work... And maybe I'm completely wrong
Hope this helps
François
"Learning French is trivial: the word for horse is cheval, and everything else follows in the same way."
Old 7th February 2002, 07:05 PM   #12
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Ok, a couple of quick observations:
Steve, I suggest you use pots of R8 and R9, and you
probably want to lower the value as Q1 and 2 probably
don't need so much voltage across them to perform
well and it cuts into your output swing. I assume
that R16 and 17 are simulation loads, and would otherwise
be removed.
Francois, I think you'll end up wanting a few hundred
ohms output resistance to isolate you a bit from the
outside world. Also, V3 and V4 can easily be the same
source.
Old 7th February 2002, 08:44 PM   #13
ftorres's Avatar
Nelson,
Thanks for your kind observations. Of course, it's far from a practical circuit, it was only for quick simulation purposes, just to test the feasability (?) of some ideas. It's a long way from computer screen to music listening
Steve,
I don't think that noise is really an issue here. My BLS is dead quiet, provided that power supply is correctly filtered.
François
Old 7th February 2002, 09:15 PM   #14
The one and only
In this case it's quite a short path. I believe you can
use it as is.
Old 7th February 2002, 09:20 PM   #15
SteveG is offline SteveG  United States
Account Disabled
Nelson,
Thanks for the advice. I will try a smaller value of pot (50K?) to dial in the gate voltage. Is there a better way of biasing the cascode fets into conduction?
I'm still not exactly clear on how to determine the operating point of the mosfets... I believe that in this case it is controlled by the current source, but I'm not sure how to determine the optimal value of load resistor and current. Does the gate voltage not matter, as long as it is biased above 4-5 volts?
paralleling mosfets in BLSHide this!Advertise here!
n/p Mosfets vs depletion mod mosfets marcello7x Car Audio 6 4th October 2006 05:01 AM
When paralleling opa549 bigmike216 Chip Amps 5 16th May 2005 08:07 PM
Paralleling large number of Mosfets. danieljw Solid State 47 26th February 2005 05:43 AM
resistors for paralleling ejn327 Chip Amps 8 7th February 2005 08:10 PM
Paralleling LM3886's-the right way jan.didden Solid State 15 4th November 2003 11:59 AM
Copyright ©1999-2017 diyAudio
