Pass at BAF 2012 - Page 2 - diyAudio
Closed Thread
Old 19th October 2012, 01:36 AM   #11
a.wayne is offline a.wayne  United States
Sin Bin
Bwoy,
Am i out of the loop or what , what's an F6 and why should i like it,
Is it ZM endorsed .
Old 19th October 2012, 02:56 AM   #12
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by buzzforb View Post
All attending people would be forced to flee from the impending irrational and overly exuberant conversations, interesting only to me.
That actually sounds very interesting, and entertaining. You should go! What the heck, last minute stuff can be cheap...
Old 19th October 2012, 03:12 AM   #13
buzzforb's Avatar
HA! Thanks 6L6. Iwish.
...Shape the sound , Man!
Old 19th October 2012, 02:20 PM   #14
Originally Posted by wrenchone View Post
I have some things to tickle those field coils...
The Lowther website writes about a Hi-Ferric technology in its DX series. Interesting mechanism of action. A rear-view picture of a DX driver did not show independent connections to "field coils"; as reminescent of ancient drivers. It has a magnet, and only the usual two connections to a power amp. The peak excursion of the diaphragm was quoted at 2 millimeters peak to peak. Prices [in Pounds Sterling] appeared reasonable in the range for~280-550. However; no impedance versus frequency plot was shown for any one driver.
Old 19th October 2012, 03:02 PM   #15
The following is a brief excerpt from the write-up on the field Coil Lowther at www.lowther-america.com.
"The field coil Lowther is a brand new design. It uses current through a large copper coil to create the magnetic field rather than the standard permanent magnet".
Details at web site.
Old 22nd October 2012, 09:01 PM   #16
Default SIT [or other FET] driving the Field and Voice Coils of Lowther
Mr. Pass: The Rothacher SIT amp Version 2 used an inductance as a load to the SIT. I have [mentally] replaced Rothacher's coil with the Field Coil of the Lowther you'll be using for BAF 2012. The attached file [lowthersit.pdf] shows a proposed schematic whereby a SIT [or other FET] simultaneously drives the Field and the Voice Coils of this loudspeaker. This is a new situation of a fixed plus a signal modulated loudspeaker magnetic field. By comparison, Lowther-America recommends using a clean DC power supply to generate a fixed magnetic field.
Old 22nd October 2012, 09:10 PM   #17
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
somehow I have impression that both Lowther and your ears wouldn't be happy with that solution
in dark ages , FC of speaker was used as choke in PS , for tooboolar amps ; and even then,when Movie Theater was crowded , demanding more A2 from flea powerful amps ..... entire first row of spectators wasn't entirely happy .......
then they invented pentodes and PP , screaming how there is free lunch , at last
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 22nd October 2012, 09:21 PM   #18
never say never.
Old 22nd October 2012, 09:24 PM   #19
The one and only
Nelson Pass's Avatar
I think you could get away with it at low levels. I will be using a regulated
supply, however.
Old 22nd October 2012, 09:33 PM   #20
Zen Mod's Avatar
never say never.
intention of revived (not just nowadays) using of FC in speaker construction is impeccable constant magnetic flux , not influenced with constant variable EMF made by vibrating voice coil
sort of idea that FC is having much lesser "intrinsic impedance " than any permanent magnet
even if you embrace idea of using FC as (even just partial ) choke load for amp , connected to counteract non-linear distortion in rest of speaker/amp combo , I resume that having any success demands sooooooooo complicated and loooong process
not fun
Closed Thread
Pass "DeLite" Amp from BAF Vix Pass Labs 834 13th November 2016 07:34 AM
SEC DIY 2012 Speaker Show - Mobile, AL - November 10th, 2012 Tieftoener Clubs & Events 2 7th November 2012 10:56 PM
The Pass room at BAF 2011 Nelson Pass Pass Labs 2 7th September 2011 03:33 AM
What and Where is BAF? Troncones Tubes / Valves 10 16th January 2011 02:30 AM
wool vs Dacron/BAF in TL Henkjan Full Range 6 12th September 2006 05:15 AM
Copyright 1999-2017 diyAudio
