SIT amp idea
SIT amp idea
Old 24th November 2012, 11:46 AM   #11
VladimirK is offline VladimirK  Uzbekistan
Here are some shots of the SIT amp. Since it sounds really good, I have put some efforts to decorate it, with a custom machined volume control knob (bulk titanium) and titanium screws visible at the front panel. The volume control potentiometer is Penny&Giles RF15 10kOhms.
One could mention, that I tend to some rare components. It is partially true, I simply get some pleasure from using things, that are not easy obtainable from a department store.
Old 24th November 2012, 11:53 AM   #12
The new SIT amp has been also granted with a custom made equipment carrier, made from 40mm plywood.
Old 24th November 2012, 11:57 AM   #13
Other amps that I compare to this SIT amp are the following:
1) Similar SE topology, but with HF bjt transistors instead of SIT
2) No GNFB SE amp, with Ge bjts at the output
Moreover, a tube SE 300B amp is playing at the comparisons, it was specially acquired for this purpose. Some description of this tube amp is here
http://www.nemrussia.com/home/production/a300se
http://www.ultraudio.de/nem_a_300_se.html
It is visible at the bottom of the equipment carrier, standing on the floor.
Old 24th November 2012, 12:08 PM   #14
What can I say about sound differences
All are perfect at mids and highs. They overtake even the tube amp. Most differences are at the bass region, maybe because my PMC EB1i speakers are not an easy load. Value of output impedance says almost nothing about bass impression. In my case, it depends more on a kind ot transistors used at the output. Namely, I still find, that the No GNFB amp with Ge bjts at the output gives the most "detailed" and naturally sounding bass, athough other amps also produce "big" and powerful sound.
Most time I am listening to the SIT amp and to the No GNFB Ge amp.
SIT amp ideaHide this!Advertise here!
L'Amp: A simple SIT Amp ra7 Pass Labs 2919 10th May 2018 06:00 PM
LíAmp: A Simple SIT Amp: Part Deux Michael Rothacher diyAudio.com Articles 19 13th April 2017 12:11 PM
SIT-1 and SIT-2 owner manuals Nelson Pass Pass Labs 25 12th September 2012 07:16 PM
L'Amp: A simple SIT Amp and F6 dantwomey Pass Labs 9 6th June 2012 07:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
