Best Pre-amp to build for a new DIYer?
Old 28th October 2003, 07:51 PM   #1
hifimaker is offline hifimaker  United States
hifimaker's Avatar
Question Best Pre-amp to build for a new DIYer?
Hey,
Pardon "newbie" question.... but
I have a Rotel 990BX amp and 970BX pre-amp, and I'm interested in upgrading my pre-amp. Being short on funds and always wanting to build a pre-amp, this seems like a good oportunity to jump in and build one.
My question is: Should I consider building a "Son of Zen" pre-amp or maybe an Aelph P pre-amp?
Any suggestions for a first time build would be appreciated. Also, any recommendations for a PCB source is appreciated.
Thank you,
-David
Old 29th October 2003, 12:04 AM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
BSOZ and Aleph P are largely the same preamp. I recommend
BSOZ due to its greater simplicity. You don't want to tackle the
attenuator of the P as a novice.
Old 29th October 2003, 05:23 PM   #3
ElectroNick is offline ElectroNick  Netherlands
ElectroNick's Avatar
How about the Bride of Zen ?
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Works fine for me ....
Grtz,
Nick
Old 29th October 2003, 06:47 PM   #4
hifimaker's Avatar
Default Nice
WOW, what a nice looking pre-amp. Can't wait to build one of my own.
I'm thinking of building BOSOZ preamp with the Croation PCB's. http://web.vip.hr/pcb-design.vip/bls.html
Someone let me know if there is a better board available.
Thanks for sharing,
-David
Old 29th October 2003, 06:57 PM   #5
hifimaker's Avatar
Default Thank you Mr. Pass
Thank you Mr. Pass for your recommendation. After looking more closely at the designs, the BSOZ does seem more appropriate. Yes, BSOZ and Aleph P are essentially the same preamp.
I appreciate the recommendation.
Now to find the right BSOZ board...
-David
Old 29th October 2003, 07:10 PM   #6
jarek is offline jarek
BSOZ and Aleph P are largely the same preamp. I recommend BSOZ due to its greater simplicity.
Hi Nelson,
What running temperature do you like for IRF9610ís in BLS? On the board is rather little space for heatsinks. Mosfets go very, very hot. Does this have a important influence on the performance?
Jarek
Old 29th October 2003, 07:55 PM   #7
BobEllis is offline BobEllis  United States
BobEllis's Avatar
My BoSoZ rund darned hot too. I think that it is higher current that makes for better sound, not temperature. If you can keep the temperature down, it will live longer. With the recommended heat sinks I measured 75C case temperature at +/-62 Volts on the rails and 80 mA draw per channel.
I built my regulators (one pair per channel) with 1x1x1.65" heat sinks - they run less than 50C, they would have been mighty hot with the heat sink called out in the article - about 4 watts if you use a single regulator for both channels.
there is another heat sink that is the same width as the recommended part, but has significantly longer fins(perpendicular to mounting face.) A couple distributors I checked had them. I'm waiting for delivery of some, I hope it is enough. if not, I'll rebuild with the bigger extrusions used in the power supply (and while I am at it change over to CCS).
Old 29th October 2003, 08:15 PM   #8
Squalish is offline Squalish  United States
GILMORE DYNAMIC!!!
Well, perhaps not for newbies. Originally a headphone amp, but can also be used to great affect as a preamp.
The PS is the only thing that needs heatsinks, and even then, four medium-sized to-220 sinks should do good. To cut down on heat a ton, you can safely downgrade the toroid from 35v to either 18v or 22v.
You can protoboard it or buy a PCB on Antness' page.
Around $200 w/ an alps blue($350 w/ a dact) to DIY it.
Old 29th October 2003, 08:28 PM   #9
till is offline till
Banned
You don't want to tackle the attenuator of the P as a novice.
what do you think about this as an alternative: http://home.tu-clausthal.de/~tpa/relais/relais.html
and what about the sound ?
Old 30th October 2003, 06:15 AM   #10
Nickolas K. is offline Nickolas K.
Nickolas K.'s Avatar
Default dw8083
Does your Rotel amp have balanced inputs?
Because if it doesn't you don't need a balanced preamp.
Just go for the AlephL.
Nick
Is this phase one of Lumpy Gravy?
Best Pre-amp to build for a new DIYer?Hide this!Advertise here!
Sansui SR 525 Needs DIYer dmannnnn Swap Meet 0 19th April 2009 06:40 AM
My name is Hendrik and I am DIYer hendrikxix Introductions 3 15th May 2008 03:18 PM
WTB: Would like to commission a diyer to build me a pair of speakers mlaroche Swap Meet 18 20th November 2006 03:09 AM
New DIYer needs help. Tov Multi-Way 16 25th March 2004 02:59 AM
Copyright ©1999-2017 diyAudio
