Pass Class A/B designs for HT? - diyAudio
Old 2nd October 2012, 02:45 PM   #1
ORNJ is offline ORNJ  United States
Default Pass Class A/B designs for HT?
Hey guys, I have been looking at building/buying amps for a while for my HT system as I didnt really know the direction I wanted to go with it.....
However, I think I have decided that I dont want to try and integrate my music system into my theater system and just build some good Class A/B designs.
I know that Pass has a Class A/B 5 channel amp but I haven't been about to find much information on it. However, It may be better for me to just make some 2 2channel and 3 channel at first because I use my receiver for all audio now as the built in speakers in my TV are terrible.....and I am now spoiled with audio.
and there is no reason to have all five channels turned on if they are not being used....
Also, can anyone tell me how much it approx. costs to build one of the class A/B designs? Not including the case...
I ask cause I am looking at how to budget everything. I know there are premade cases out there but I may be able to just get ahold of some heatsinks and build a wooden box...
Old 2nd October 2012, 02:53 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
https://passlabs.com/discontinued-products/
X3 and X5
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 2nd October 2012, 04:58 PM   #3
yea thats the only thing I have been able to find in the past as well. But I havent been able to find anything about building one. granted, Passlabs website has the hardware facts but there are no circuit design plans from what I can see.
Old 2nd October 2012, 05:23 PM   #4
Zen Mod's Avatar
1.room size
2. which speakers
3.your presumed power per channel and how many of them
4.listening habits
then we can talk
Old 2nd October 2012, 06:10 PM   #5
1. its a pretty small room, I dont have exact measurements as I am at work but I only have room for a couch and a single chair in my family room. But the room does open up to the kitchen, hallway, and entry way and has high ceilings. I am driving everything from my receiver right now which only has about 75 watts I believe.
2. I currently have some SVS bookshelf speakers but I am also working on some High efficiency 2 way speakers with the goal of having them be about 90db 1w/1m sensitive or higher with a 1.4" CD and 8" woofer with the plan to cross no lower than 60hz to the subwoofer
3. I only see the need for 100-150 wpc as I am more about having efficiency then having enough power running through the room to be able to power half of new york city....I want Pass amps though for their quality of power they can feed my speakers.
4. in the room that these amps will be going in is about 70% movies/tv and 30% music. Most music is listened to in my office where I currently have a bottlehead quickie preamp, adcom 6000 amp, and JBL 120ti monitors....I hope to build some frugal horns or some sort of full range horn for this room along with an F5 or bottlehead amp.
Old 2nd October 2012, 06:16 PM   #6
Zen Mod's Avatar
90db/W/m spks will sing with F5 amp , if helped with some nasty active subwoofer
regarding AB Pass amp , probably best/most easier thing is exactly F5 , made with laterals and biased lower than original
or something as that , made on F5 Turbo basis , with higher voltage , lower bias and laterals , for lesser Klunk!
anyway - 100-150W/ch is somewhat too optimistic , if you're counting on PL basis , without much heat
Old 2nd October 2012, 06:23 PM   #7
Thats fine. I dont need 100-150 watts as I subscribe to the "first watt" theory.
Simple logic to me that other disagree with...but 90db 1w/1m is loud in most situations and if that is only with 1w....I just want to make sure it can handle any peaks.
I thought about the lower bias approach that you mention because from what I understand, the lower the bias the more power available but the higher amount of distortion is present....correct?
So I would just need to choose a "sweet spot" of balancing distortion and power....
Old 2nd October 2012, 06:38 PM   #8
Zen Mod's Avatar
if you're going to stereo + active sub ( mostly for movie shake) , then even A class augmented F5 will fulfill your needs , without too much sweating
I'm speaking of 2SJ201 & 2SK1530 as outputs , because they're better if bias is lower , comparing to IRF mosfets; that in case you can't afford so much heat
as you said , first watts are most important , so even with lesser A class amount you'll be good
Old 2nd October 2012, 07:10 PM   #9
Any idea what my target watts should probably be? Im wondering what a good compromise in bias would be....especially since lower bias means lower power draw while running compared to the massive 100w draw from higher bias designs.
Old 2nd October 2012, 07:14 PM   #10
F5 turbo V2 with low bias. say 0.8A bias. and +/-38V rails?
that will give you just over 60W dissipation pr ch. at idle. and 10W classA at 8ohm. and about 75W or higher class A/B at 8ohm.
HT rig powered by the designs of the one and only Redwingnine Pass Labs 0 4th January 2012 12:19 AM
ThermalTrak and Class A Pass designs NYCOne Pass Labs 4 12th July 2011 09:32 PM
Elemental Designs EHQS12 as a HT sub? santiu Subwoofers 45 27th December 2007 09:16 AM
Hexagonal HT system cabinet designs Andy G Multi-Way 0 25th December 2002 10:47 PM
Copyright 1999-2017 diyAudio
