Old 28th October 2003, 10:54 AM   #1
Default My little passive preamp
It's not Aleph ,but I hope Nelson and others won't mind putting it here.This is my small toy I built some time ago,after I found nice 22 positons,4 deck switch in local surplus store.The piece of wood was a part of old (over 50 years) shelf that I found in attic.You can see those little holes made through years by insects.
This is ladder type 4,7K attenuator.After some reaserch I found that even Elma and Gold Point ladder type attenuators are not really ladder becouse in some couple of close positions they work as shunt types.
This is becouse of lack of calculated values (one would have to custom order resistors values).I figured that both resistors (signal and ground) can be built of two in parallel.Then creating Exel sheet with regular values and the formula for paralleling resistors gives hundreds of values that one never finds in regular production values.
The bad side is that I needed twice as much resistors and the benefit: the input impedance is rock steady regardles of position (-/+ 2-3ohm).
It took me three days to solder them.Was it worth it? I'm not sure ,probably not,but I had fun.
Also I found local company that produces custom values high quality resistors (0,1% , 10ppm , non-inductive) so next time I might try them.
Bartek
Old 28th October 2003, 10:56 AM   #2
more
Old 28th October 2003, 11:00 AM   #3
and some more
Old 28th October 2003, 11:01 AM   #4
next one
Old 28th October 2003, 11:02 AM   #5
JOE DIRT®'s Avatar
Hell!!!...that is SWEET!!!!LOL....fine Job on that!!!
Cheers!!The DIRT®
Old 28th October 2003, 11:03 AM   #6
thanks
Old 28th October 2003, 11:04 AM   #7
resistors close
Old 28th October 2003, 11:06 AM   #8
back
Old 28th October 2003, 11:07 AM   #9
side
Old 28th October 2003, 11:09 AM   #10
that's the last I have
F1 and a passive preamp? roscoeiii Pass Labs 10 10th May 2009 12:55 AM
passive preamp mjh77 Analogue Source 4 14th August 2004 10:06 PM
Passive Preamp Rarkov Analogue Source 77 15th April 2003 06:51 PM
Passive preamp Flemming J P Everything Else 7 5th November 2001 09:40 AM
Page generated in 0.10034 seconds (82.28% PHP - 17.72% MySQL) with 11 queries
